Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Battery Question
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk
Ron Corkum
PostPosted: Wed Nov 14, 2012 5:37 am    Post subject: Battery Question Reply to specific post Reply with quote
If a fully charged, disconnected battery is left exposed out in the rain ,will it discharge?
Seems to me water is a conductor of electricity.
It rained here last night and I am looking out at my exposed battery sitting there in the rain,this morning!Does anyone have experience with this type of battery exposure?
jackinok
PostPosted: Wed Nov 14, 2012 5:45 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
probably not,wont help it,but i doubt it will discharge it.driving in the rain leaves underhood components wet,and they dont discharge.sun on the case is probably worse because they are not likely to be uv protected very well. but that would take some time.
John B.
PostPosted: Wed Nov 14, 2012 5:58 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
Moisture between the posts of a battery will cause a light discharge. It can take months, but as the moisture collects dust and it stays moist the faster the discharge. This is why they recommend keeping a battery clean.
Many people have not heard of or seen this. Take a volt meter, put one lead on one post and touch the top of the battery anywhere and watch what reading you get. This proves that moisture on top of a battery conducts electricity.
LJD
PostPosted: Wed Nov 14, 2012 6:00 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
All flooded lead-acid batteries "self discharge" regardless if wet or dry. Heavy duty batteries with more antimony inside discharge even faster. Most auto batteries discharge at 5%-10% per month when unhooked. Some AGM (absorbed glass mat) lead-acid batteries discharge less.
Mike (WA)
PostPosted: Wed Nov 14, 2012 6:02 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
I had a tractor that sat for 4 years, outside, with top post battery exposed to the weather (and disconnected). It started the tractor without external charging when I finally got tractor fixed. Average rainfall here is about 40 inches a year.
Russ from MN
Clean water does not conduct electricity, however the top of the battery probably has some dirt on it. A good hard rain would probably wash off all the dirt in a few minutes. There are may reasons you shouldn't leave a battery sit outside, one is they are worth 10-$20 for scrap!
ohiojim
pure water will not conduct electricity,...only the minerals in it will,
Dick2
PostPosted: Wed Nov 14, 2012 6:15 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
I was told that the way to harm a battery more than any other way, was to install it and not anchor it down firmly. I knew lots of farmers that just put a battery in a case or frame and let it bounce around because it was not bolted down.
Rain shouldn't hurt the battery at all. Not securing it in place will harm a battery.
David G
PostPosted: Wed Nov 14, 2012 6:18 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
Wash the top off, then should be fine. The wet contaminates conduct, not the water.
buickanddeere
PostPosted: Wed Nov 14, 2012 7:16 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
The 900MW , 1.2 million HP generators run cooling water through the hollow stator bars . Stator bars operate at 27,000 volts.
pete black
PostPosted: Wed Nov 14, 2012 7:34 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
however: does the cooling water in the hollow stator bars actually come in contact with the stator coils?
pete black
old
PostPosted: Wed Nov 14, 2012 7:41 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
Not likely to cause any problems. Just to prove it you can take a jar f distilled water and put 2 wires in it and hook those one side to a light bulb and the other to a post oif the battery and the other side if that bulb to the battery and the light will NOT light up. Water does not conduct electricity. Ya rain water does have impurities that might conduct but you would have to have a very dirty rain to cause much if any problem
donjr
PostPosted: Wed Nov 14, 2012 9:00 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
It won't normally hurt it. Pure water conducts very little voltage, if any. Rain water is not pure, and dirt and trash on the battery between the posts will cause a minor discharge but it is very small, and normally does not affect normal use. A larger buildup will cause it to discharge this way more rapidly, but even then, it may not be noticed in normal use. Most water, due to impurities, is slightly conductive. Distilled water is about as pure as you can get. Rain water only has dirt and particles of dust and other contaminates it may have picked up in the atmoshere and is also very close to being pure.
buickanddeere
PostPosted: Wed Nov 14, 2012 10:08 am    Post subject: Re: Battery Question Reply to specific post Reply with quote
Cooling water runs right through the middle of the hollow 27,000V energized stator bars. Stator bar is approx the dia of a beer can and 30 feet long.
Goto page 1, 2  Next
Page 1 of 2
