ford naa starter
capy1958
PostPosted: Wed Nov 14, 2012 7:35 am    Post subject: ford naa starter Reply to specific post Reply with quote
How do you get the pass thru bolt off starter of ford naa and install a new one.Thanks for help.
old
PostPosted: Wed Nov 14, 2012 7:50 am    Post subject: Re: ford naa starter Reply to specific post Reply with quote
The NAA should have the flange mount type starter. The last of the pass thru type came on the 8N then they change to the flange mount so what tractor do you really have. As for how to do the pass thru you simple pull them like you would any other bolt then carefully slide the start out till you can install 2 nuts so the starter does not fall apart on you and then pull the starter. If it has the pass thru bolts they take a 5/16 nut
capy1958
PostPosted: Wed Nov 14, 2012 7:55 am    Post subject: Re: ford naa starter Reply to specific post Reply with quote
It is a naa ,I have starter off and it has a pass thru bolt that comes off from inside. I have rebuild kit for naa with new one.
