| Author |
Message |
Jay VW New User
Posted: Wed Nov 14, 2012 8:07 am Post subject: WD parts |
I am getting a 1953 WD running for the first time in 20+ years. I changed all the fluids and was able to get the tractor running. The only problem that I am having is high oil pressure. I took out the oil pressure relief valve and when I removed the plug the spring was broken and the plunger is stuck or rusted in. I have two questions, how do I get the plunger out and where do I get a new spring and plunger? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50476 Location: Lake of the Ozarks area of MO
Posted: Wed Nov 14, 2012 8:56 am Post subject: Re: WD parts |
Agco should have those parts. You best check the oil filter since it to has a lot to do with oil pressure or the lack of pressure |
| Back to top |
schriffs Regular
Posted: Thu Nov 15, 2012 6:09 pm Post subject: Re: WD parts |
To remove the plunger, it might work to try tapping threads into it and pulling with a bolt. Or use a thread extractor, there are short ones with tighter spirals that don't have a lot of taper (as opposed to the long spiral ones that cover a wider range of hole size per tool). That might be able to get it loosened up enough to pull it out. Another thought - turn the engine over and see if the oil pressure will push it out. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
