| Author |
Message |
Brokengun Long Time User
Posted: Wed Nov 14, 2012 3:04 pm Post subject: 930 front loader advice |
I’ve been thinking about putting a loader on one of my 930CK for a while and I am looking for advice on what loaders can be used for a 930CK.
Both of my 930CK have the tires set in on 30 inch rows and I have noticed some loader frames may not work if the tires are moved for 30 inch rows
I can not seem to find a case loader such as a model 70 and I do not want to buy a new one like Westendorf WL-42.
I have looked at pictures of new loaders this afternoon and I can’t seem to find any info on the type of brackets they use.
I would like the simplest loader possible without have a frame so large I can’t work on the tractor.
I actually ran across a picture today of a 930 with a Paulson loader but I couldn’t tell how it attached to the tractor.
It seemed like a very simple loader but a little light weight.
If any of you have a picture of a 930 with a loader can you please share it I would like to see as many options as possible before I start my search |
| Back to top |
Adirondack case guy Tractor Guru
Posted: Wed Nov 14, 2012 3:32 pm Post subject: Re: 930 front loader advice |
I have a friend with a very good 70 loader for sale $2000. Came off 730CK. I don't know which rear brackets are with it. you may need to extend the bottom rails to fit 930. We are in Central NY. 13333
Loren |
| Back to top |
casecollectorsc Long Time User
Posted: Wed Nov 14, 2012 4:10 pm Post subject: Re: 930 front loader advice |
There's a 800 Great Bend, which is the same as a Case 70 for $800. My nephew has a IH 2000 which is the same as a 70 Case for $750. Neither one has a weld on them. I had the IH on a 800 for a while last summer. Good loaders!! I've had one since I bought a new one in 71. First on a 800, Since 80 on my 1030. Loaded thousands of square bales with it plus hundreds of loads of poo!! |
| Back to top |
E. Schoen Guest
Posted: Wed Nov 14, 2012 7:13 pm Post subject: Re: 930 front loader advice |
I just bought a 930 CK that the previous owner had a DuAll loader on it. I have 3100 DuAll loaders on a 730 and an 830 they are good loaders. |
| Back to top |
bradley martin Long Time User
Joined: 05 Aug 2007 Posts: 927 Location: London, Ontario Cananda
Posted: Thu Nov 15, 2012 3:41 am Post subject: Re: 930 front loader advice |
I installed a new Allied 790 loader on a 930 back in 1988. Since then, we have used (and abused) it to no end. The loader will actually lift the fully ballasted rear end of the tractor if shoved under a too heavy object. I would guess that its safe lift capacity is around 3,000 lb. We have had the occassional break on the loader(particularly the quick attach for the bucket) but those usually occurred when using the outfit in place of a bulldozer!!! The tractor has handled it well, although the weakness of the pwr steering shows up. I have the wheel tread set out @ about 72" for safety on the tractor but see nothing that would prevent a 60" wheel tread. I will try to get you a picture today. |
| Back to top |
Posted: Thu Nov 15, 2012 1:26 pm Post subject: Re: 930 front loader advice |
Casecollector where are these 2 loaders located?
Do they come with brackets that will fit a case 930? |
| Back to top |
Posted: Thu Nov 15, 2012 3:50 pm Post subject: Re: 930 front loader advice |
East central South Dakota, 80 miles north of Sioux Falls. The brackets are easy to make but most will adapt to fit Case tractors. Great Bend and Case made extensions so they would fit 6 cylinder tractors. Easy to make also. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
