Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
No oil pressure
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
Gene in La.
PostPosted: Wed Nov 14, 2012 11:25 pm    Post subject: No oil pressure Reply to specific post Reply with quote
The other day while bushhogging I lost oil pressure! Story; tractor runs hot brcause radiator needs cleaning out; so after cooling radiator down by running water over, I started back to field (no "0" oil presure) removed oil pump cleaned, looked OK; still "0" oil pressure: good oil gauge no oil from block: Any ideas; or replace oil pump!!! Sorry for long post; Thanks Gene
miner09
PostPosted: Thu Nov 15, 2012 5:31 am    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Did you take oil line off and see if you were getting oil to gauge?
John(UK)
PostPosted: Thu Nov 15, 2012 5:37 am    Post subject: Re: No oil pressure Reply to specific post Reply with quote
You will need to drop the oil pan and check the Pump and while you have it off, you should check the bearings on the Crankshaft as well.
What is the oil like right now, have you got the correct grade in there, are there any unusual noises coming from the engine now. No pressure is not good. It could be that the Pump is not turning due to something shearing, drop pump and take it apart to measure wear at the end of the lobes on the "gears", should be no more than .010", if the wear is approaching that anyway, it needs changing, you can check components while you do all this. The Radiator needs cleaning out often 2 or 3 times a day when it is dusty and there is vegetation blowing around, the same applies to the Air Cleaner as well. Use a hose from the engine side to the front and make sure that you get all over the radiator especially into the corners. Use a light at the engine side and look in from the front so you can see just where there is any blockage. If you allow the engine to overheat like this there is a big danger that the Cylinder Block or the Head will fail.If you need help, just ask..John(UK)...fergusontractors@hotmail.com
Gene in La.
PostPosted: Thu Nov 15, 2012 9:36 am    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Yes, I checked at block, by removeing connection at block to gauge; no oil came out; that's why I dug futher into block at oil pump!!!
Jerry/MT
PostPosted: Thu Nov 15, 2012 11:20 am    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Make sure the oil pick up tube is not cracked or leaking and that the presure relief valve is not stuck open. Is the oil pump drive gear pinned to the pump drive shaft.
Gene in La.
PostPosted: Thu Nov 15, 2012 7:26 pm    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Radiator I mean the inside, the out side I keep real clean. Oil is ok, 10w30, could use a change but ok. Noise no unusual. When I took pump apart and removed a spring by removeing a carter pin; it effected nouthing???
Gene in La
PostPosted: Thu Nov 15, 2012 10:13 pm    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Yes but no oil from block
John(UK)
PostPosted: Fri Nov 16, 2012 7:37 am    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Then it looks like either the pump is worn or the bearings on the crank....but check the pump for wear...John(UK)...fergusontractors@hotmail.com
Jerry/MT
PostPosted: Sat Nov 17, 2012 5:43 pm    Post subject: Re: No oil pressure Reply to specific post Reply with quote
Was there a piston at the top of the spring in the releif valve? Was the spring the correct one? It can be shimmed to providea higher relief pressure.When you say "it affected nothig" what do you mean?
