Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
EMP resistant tractors ?
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk
jCarroll
PostPosted: Thu Nov 15, 2012 3:15 am    Post subject: EMP resistant tractors ? Reply to specific post Reply with quote
EMP - Electro Magnetic Pulse - electromagnetic pulse
Having nothing more to worry about, I'm wondering when tractors adopted components which would fail if subjected to an EMP. Or stated differently, how old would a tractor need to be to be "immune" from EMP in the midwest?
LJD
PostPosted: Thu Nov 15, 2012 5:01 am    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
I don't know if any of them would fail. The biggest EMP problem, in theory, is for devices with integrated circuits that are hooked to things that act like antennas and absorb the pulse. That can be the electric grid, actual antennas, etc.
Little recent "real world" testing has been done since above ground nuclear testing has been banned since the early 60s.
Regardless - I assume any tractor that lacks ICs to run is absolutely safe. Gas engine with ignition points and coil, diesel with mechanical injection, etc. The only parts of some of those tractors that may have an IC or two are the charging systems IF they have alternators with ICs in the regulators.
Chip812
PostPosted: Thu Nov 15, 2012 6:33 am    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
As far as I know, diesel tractors should run without any electrical components.
Fawteen
PostPosted: Thu Nov 15, 2012 6:45 am    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
Older ones, yes. I don't even need a key, a screwdriver will start it in a pinch.
Newer ones, with all the EPA-mandated electronic controls? Dunno for sure, but I doubt it.
Also, last I knew, the circuit traces on a printed circuit board were enough "antenna" for an EMP to toast the board.
old
PostPosted: Thu Nov 15, 2012 7:45 am    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
Any of them that have the points condenser and coil and battery will be just fine in an EMP since those are machaical (sp) type systems. It is the electronic ignition systems with chips in them that will be fried
David G
PostPosted: Thu Nov 15, 2012 11:42 am    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
I would only feel secure having a diesel with mechanical injection, running and manual fuel shutoff.
wisbaker
PostPosted: Thu Nov 15, 2012 12:12 pm    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
IC's can be hardened to prevent damage from EMP. Today's combat aircraft have a lot of solid state devices yet they consider the Aircraft to be nuclear hardened. The trick is to collect the emr's (electro-magnetic radiation) and dissipate it. Remember dealing with the debates on repairs on our Aircraft when I was in the Air Force, we had to be real careful about any wiring harness that was shielded to insure we didn't mess up the shield and we maintained all grounding and bonding of components. When I moved into an EOD slot some of the fuzes and other components were EMR sensitive so some of the render-safes involved a technique called WIF (wrap in Foil) or bed it in a sand filled steel ammo can. Much equipment is tested for EMR interference, a lot of cars and equipment used to go to upper Michigan and be tested on the ELF line up there to see if could get scrambled by the EMRs. They also test the vehicles to insure they don't emit EMRs that could mess themselves or other vehicles up. I'm waiting for someone to try using the EMR excuse for runaway vehicles.
buickanddeere
PostPosted: Thu Nov 15, 2012 12:45 pm    Post subject: Re: EMP resistant tractors ? Reply to specific post Reply with quote
Diesel with mechanical injection AND a generator instead of a alternator. A points equipped gasser would start back up after the pulse passed.
A vacuum tube radio would be ok.
