Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Coil 3400
Post new topic    Yesterday's Tractors Forum Index -> Ford
Billy the kid
PostPosted: Thu Nov 15, 2012 3:16 am    Post subject: Coil 3400 Reply to specific post Reply with quote
1st I want to say thanks for all the help.
I still am a little Confused about one thing.
Why would you need a resister with a 6 volt coil
but I can replace with a 12 volt coil and not need one?
Does the new 12 volt coil have one built in to the coil?
Keith Williams
PostPosted: Thu Nov 15, 2012 4:49 am    Post subject: Re: Coil 3400 Reply to specific post Reply with quote
Billy the kid,
First lets start with:
"Well I have power at the coil on start and run. I tested with a test light. I guess I need to put a volt meter on the coil input wire to see what I get.
When I jump the coil the old girl will run."
When you jumped the coil, You supplied power. It must have not had enough power already!
"Why would you need a resister with a 6 volt coil
but I can replace with a 12 volt coil and not need one?"
Long story short. You need a certain amount of current to run through the circuit (as in Amps) to create a spark. Amps equals volts divided by resistance. The problem is volts are different when you start vs when running. Maybe 8 volts left when you crank the engine. Around 14 volts when the engine is running and the charging system is working.
So the old way to do that on a 12 volt system was to run two wires to a low resistance coil (called a 6V coil). Wire number 1 came from the starting circuit, since the voltage is low when starting, no additional resistance is needed. Wire number 2 comes from the running circuit, you need resistance to limit the current, so they add a ballast resistor. In both cases the current is enough to create a spark.
Now the coils (called 12 volt) can be placed directly in the circuit and are able to produce a spark and limit current under both the start and running conditions with out additional resistance. These coils are marked "No resistance needed".
I hope this brings to light some of the info you need.
JMOR or several others can explain more if you need it. Just let us know if this is enough.
Keith
souNdguy
PostPosted: Thu Nov 15, 2012 5:30 am    Post subject: Re: Coil 3400 Reply to specific post Reply with quote
Keith actually covered it pretty good.
them 3 cyl's used a 6v coil and a resistor wire. the r-wire was in the run circuit. at startup, the 6v coil was powered by full bat votlage.. or whatever was left after the starter took it's share.
there are various ways to do it. old fords used a thermall sensitive resistor.. newer setups could use a solenoid with a bypass line on it.. or simply a different tap off the key switch, etc.
newer oil potted coils can handle heat disipation better and thus can be run a lil hotter that an older dry or hard epoxy or even older hard tar-like potted coils.
Billy the kid
PostPosted: Thu Nov 15, 2012 6:16 am    Post subject: Re: Coil 3400 Reply to specific post Reply with quote
No think that will do it.
You guys are always a great help.
I was doing my 8n over last year and again this was a great place to get info!!!!!
