Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
av gas
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
north puller
PostPosted: Thu Nov 15, 2012 3:46 am    Post subject: av gas Reply to specific post Reply with quote
What's the real deal with av gas?
I have run some in my tractor and I worked out well. I found that it runs a little bit leaner than regular gas.
I know that it is leaded and has aprox 100 octane.
I think that to prevent vapour lock it doesn't vapourize as eaisly as regular gas.
Some say that it runs very dry.
Some say it is a good fuel to run, and some say that it is garbage.
Just wondering, is the vapourization characteristic good or bad? How much lead does it really contain and is that good or bad? How lean does it really run? How dry does it really run?
What's the difference between av gas lean/rich knock index and gasoline's octane rating?
Av gas is a cheap fuel, but is it any good to use? Is it any worse for deposits than any other leaded fuel? Are there any other reasons that av gas would not be a good fuel to use?
Ole Johnny
PostPosted: Thu Nov 15, 2012 11:02 am    Post subject: Re: av gas Reply to specific post Reply with quote
I will explain it like this. They use it in air planes IN THE AIR with NO PLACE TO PULL OVER and work on it. It is VERY VERY good fuel and at 100 octain and low led, it is MUCH better on tractor engines and high horsepower engines than ANY pump fuel you can find.
buickanddeere
PostPosted: Thu Nov 15, 2012 12:57 pm    Post subject: Re: av gas Reply to specific post Reply with quote
Being scared of 100LL for no reason seems to be the worst problem.
It's fairly high octane and very clean. Run it or any other fuel a little rich for extra detonation resistance.
dyno octane
PostPosted: Thu Nov 15, 2012 4:54 pm    Post subject: Re: av gas Reply to specific post Reply with quote
dyno it. then, put it back on gas n see how much power you can lose with av gas. ive seen it cost a close to stock M farmall,, 10hp! yea, it ran great till under power she just dies quicker. some can gain, some will not.
51JDAinPA
PostPosted: Thu Nov 15, 2012 7:21 pm    Post subject: Re: av gas Reply to specific post Reply with quote
He"s got one thing right. They use it in the air with no place to pull over. And unless the track you are pulling on is at 10,000 feet of elevation you are shooting yourself in the foot. Our A that is mildly built lost 15 horsepower on the dyno compared to premium 93 octane with TORCO fuel additive. Aviation gas just plain isn"t made for low elevations. Thats why they use at high elevation where air is thinner and NOT on the track...
LarryM
PostPosted: Thu Nov 15, 2012 7:48 pm    Post subject: Re: av gas Reply to specific post Reply with quote
All that matters is what the Dyno says. Without testing and verification all you have is an opinion. I have a C-281 engine in a Farmall M that I have been palying with and so far I have achieved results beyond what my expectations were. It is a C-281 engine with stock cam and head and manifold and it comformatic pistons that only create 8:1 compression ratio. I have been playing with different fuels and they range from 63 hp to 69 hp. What I have learned is that people on this site are gracious but the really really good information will not be divulged here. Check out the video.
http://youtu.be/MljPZZJlsSg
ChadS
PostPosted: Fri Nov 16, 2012 8:44 am    Post subject: Re: av gas Reply to specific post Reply with quote
your pump gas must be a bad blend.
RichB
PostPosted: Fri Nov 16, 2012 9:39 am    Post subject: Re: av gas Reply to specific post Reply with quote
What is the specific gravity of this AV gas? just curious.I use C12 in my Oliver and thats the least amount of octane I can get away with...But it ain't cheap stuff!
LarryM
PostPosted: Fri Nov 16, 2012 10:32 am    Post subject: Re: av gas Reply to specific post Reply with quote
I was going to type a long post here but then I remembered who you are.
LarryM
ChadS
PostPosted: Fri Nov 16, 2012 11:28 am    Post subject: Re: av gas Reply to specific post Reply with quote
lol. please, dont let that stop you....... go ahead, type it out. ive been there, done that, and the real proof would be that the av gas is def better than what you get at your pumps. I cant say that here. thats why it was said, sometimes it works, sometimes it dont.
um ok
PostPosted: Fri Nov 16, 2012 1:33 pm    Post subject: Re: av gas Reply to specific post Reply with quote
but it costs horsepower...apparently i'm not the only one who has seen it on the dyno as others are posting it in this thread. it's not a good gas, it's a GREAT gas, but it won't produce as much horsepower as other gasses will.
At the end of the day, the lowest octane your motor will run on without knocking or pinging will generally give you the most power, as long as you're comparing good quality gasses. some of the pump gasses are so full of ethanol and other add ins that even though they may be all the octane you need, they don't produce as much power because they don't burn as well.
LarryM
PostPosted: Fri Nov 16, 2012 1:47 pm    Post subject: Re: av gas Reply to specific post Reply with quote
Nah, People who throw out negative comments without substantiation are not worth my time.
Bouncer
PostPosted: Fri Nov 16, 2012 2:54 pm    Post subject: Re: av gas Reply to specific post Reply with quote
So are you the pot or the kettle then?
ChadS
PostPosted: Fri Nov 16, 2012 2:55 pm    Post subject: Re: av gas Reply to specific post Reply with quote
Wheres the negativity? seems to me like your shoulders chipped a lil bit more by being pissy. who says things like that? im not attackin ya dude! all i said is, its obvious your pump gas sucks and i belive you when u say you gained power from av gas over your pump gas. ive seen it 500times! Some places in the USA, have very crappy gasoline. Some places have very good pump gas that will make more power than av gas. i am not by anymeans, cutting you down. so quit that bullcrap blaming me for unsubstantiated claims. ive got 25yrs in antique pulling and LEARNED that some things work, somethings dont. Do what u wish in what you do, but when someone has a opinion, listen to it, analyze it, prove it, then, shout it from the rooftops what u learned.
i think todays lesson is, where larry lives, av gas is better than your pump gas for peak power. it is a proven fact that gas is not the same everywhere. im sorry if our pumps carry the good stuff and DOES out do av gas on the dyno. now, ive taken the time to type this out, like i said, im not attacking you larry, but ur shoulder is awful, awful cold.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
