Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
right rear axel leaking
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
ArloInt
PostPosted: Thu Nov 15, 2012 8:11 am    Post subject: right rear axel leaking Reply to specific post Reply with quote
"49" 8n... Have been reading about this problem on "Smith" old tractor web site. He is talking about "Preload" on axel. I have had this axel out before for the same problem, not sure that I have the shims in the proper spot. I am ordering a new hub as mine looks a little worn and is scared up some. Can somone shed a little light on the "Preload" setup?
am ordring the 8n fo-4 manual also. Thanks
John Smith8N
PostPosted: Thu Nov 15, 2012 8:57 am    Post subject: Re: right rear axel leaking Reply to specific post Reply with quote
ArloInt wrote:
(quoted from post at 17:11:42 11/15/12) "49" 8n... Have been reading about this problem on "Smith" old tractor web site. He is talking about "Preload" on axel. I have had this axel out before for the same problem, not sure that I have the shims in the proper spot. I am ordering a new hub as mine looks a little worn and is scared up some. Can somone shed a little light on the "Preload" setup?
Have you ever replaced or repacked front wheel bearings on a car or tractor? The bearings in the front hub are 2 tapered roller bearings facing each other. You tighten the nut on the spindle so that the wheel cannot wobble, but not so tight that it's hard to turn and would get hot from too much "preload". You don't want it tight, and you don't want it loose. You feel for that "just right" amount then install the cotter pin.
The rear axle assembly has 2 tapered bearings also, one on each outboard end of the axles. The axles butt together in the middle. On this application you don't have a nut to tighten or loosen to set the bearing preload on the axles. You have to add or remove shims to get the correct feel. More time consuming, but the same principle.
