Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JD G main bearing torque
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Cabbage
PostPosted: Thu Nov 15, 2012 9:22 am    Post subject: JD G main bearing torque Reply to specific post Reply with quote
Anyone know what the torque should be on the bolts for the main bearings in a 47 G? Cant seen to find it.Thanks!
1949ABG
PostPosted: Thu Nov 15, 2012 6:40 pm    Post subject: Re: JD G main bearing torque Reply to specific post Reply with quote
I've never been able to find any specs. I was told by an old mechanic to "tighten 'em up good, you won't break that bolt unless you use a cheater pipe." That's how I did mine.
I know, not really much help.
Rwolfejr
PostPosted: Fri Nov 16, 2012 1:46 pm    Post subject: Re: JD G main bearing torque Reply to specific post Reply with quote
Those bolts should be 5/8-11... Not positive on a G but would bet heavy that's what they are too. And my recollection is the ones on my 820 were grade 8.
Given 5/8-11 grade 8 bolt going into cast iron in a situation where the purpose is to just put a little tension on the bolts to hold it tight... you'll be good to go at about 150 ft./lbs. Run 'em all hand tight then bump 'em up to about 100-130 then 150 in a sensible pattern. There should be the thin metal tabs under them to be bent over both the head and over the edge of the casting the bearing is in... so should they try to back off they can't go anywhere.
If you were running the same into steel the recommended seating torque would be a whopping 283 ft./lbs. for grade 8 5/8-11. You don't need or WANT that in this situation.
If you don't like the way 150 feels then bump them up a little more if you like. 175 wouldn't hurt anything. They aren't critical. They'll probably handle about 225 before you'd need to worry about pitching or pulling the threads out of your casting.
