| Author |
Message |
Sharosa New User
Posted: Thu Nov 15, 2012 3:29 pm Post subject: JD 710 Diesel tractor |
I am working on my John Deere 710 tractor. Having trouble finding where to drain the hydraulic fluid from. Also what type of oil do I use in the transmission. Hydraulic system has water in it want to drain clean out and refill before winter. Having trouble getting tractor into reverse. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23714 Location: in front of computer
Posted: Thu Nov 15, 2012 4:58 pm Post subject: Re: JD 710 Diesel tractor |
1-800-522-7448 will land you a well illustrated operator"s manual .
Won"t shift? Grinds ,the shifter won"t move or the shifter moves but the gear selection won"t change? |
| Back to top |
Sharosa New User
Posted: Thu Nov 15, 2012 5:52 pm Post subject: Re: JD 710 Diesel tractor |
I agree about the manuals I'm from Canada will probably order from eBay. I can move shifter no grinding can get some forward gears but cannot get reverse gears |
| Back to top |
Posted: Thu Nov 15, 2012 6:38 pm Post subject: Re: JD 710 Diesel tractor |
Pretty much a given as Deere didn"t ship the 510 and 710 to the US. The 310 didn"t even make it across the Atlantic.
My neighbour has a somewhat functional 510. The Dubuque style 300 engine in a Lance 10 speed chassis is interesting.
Mother Deere ships the manuals no problem. Just request the post office instead of UPS. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13486 Location: Coyote Flats,Tx
Posted: Fri Nov 16, 2012 4:37 am Post subject: Re: JD 710 Diesel tractor |
| sharosa wrote: | | (quoted from post at 19:29:03 11/15/12) I am working on my John Deere 710 tractor. Having trouble finding where to drain the hydraulic fluid from. Also what type of oil do I use in the transmission. Hydraulic system has water in it want to drain clean out and refill before winter. Having trouble getting tractor into reverse. |
There should be one drain plug in bottom of trans case directly below the gearshift levers and another drain plug in bottom of diff housing. Refill with JD Hy-Gard or it's equivalent type oil.. |
| Back to top |
kseaton65 Regular
Posted: Mon Nov 19, 2012 7:33 am Post subject: Re: JD 710 Diesel tractor |
transmission and hydraulic fluid are seprate on the 710 tractor. transmission and rear end share same gear oil. hydraulic fuild is in a plastic resivoir bolted to the underside of the rockshaft housing and set inside the rear casting. there is a cap on a tee fitting on the return hydraulic line under the right footboard to drain some of the fluid. the only way to get it all out it so use an extractor to suck the resivoir empty |
| Back to top |
Sharosa New User
Posted: Mon Nov 19, 2012 8:48 am Post subject: Re: JD 710 Diesel tractor |
Wow.thanks for the info, sounds like I have a fun job ahead. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
