| Author |
Message |
Billy the kid Regular
Posted: Thu Nov 15, 2012 4:04 pm Post subject: coil 3400 |
Well just a update.
I found the wire from the ignition to the coil to be
bad. replaced it. I replaced the coil with a new 12
volt coil,checked the resistance across the coil 3.6
Starts and stays running. Except now I found the
water pump to be bad. ugh!! never ends.
Thanks guys you have been a real help. |
| Back to top |
souNdguy Tractor Guru
Posted: Thu Nov 15, 2012 4:18 pm Post subject: Re: coil 3400 |
good luck.
straight forward bolt turning.. but it's a pITA if the nose comes off..  |
| Back to top |
Greg Wolodkin Long Time User
Joined: 02 Oct 2007 Posts: 534 Location: Massachusetts
Posted: Fri Nov 16, 2012 4:54 am Post subject: Re: coil 3400 |
I replaced my water pump recently. Already had the hood and nose tin off, so I pulled the radiator. It was an easy job. I've read that the pump can be replaced without taking the nose off, but it seems like it would be a much harder job.
If you do take the nose off and pull the radiator to do it, you might consider dropping a new fuel pump in while you're there. Short money, easy to do while you're in there.
Hope this helps -
Greg |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
