Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
head straight
TUCKAWAY
PostPosted: Thu Nov 15, 2012 4:05 pm    Post subject: head straight Reply to specific post Reply with quote
c123 farmall 100 how do I know that the head is straight when I put it on the block ? no dowel to line up.
John G. Hasler
PostPosted: Thu Nov 15, 2012 5:42 pm    Post subject: Re: head straight Reply to specific post Reply with quote
Make some dowels by cutting the heads off some bolts of the right size. Grind flats on them to make them easy to get out after you put the head on. No need to use proper head bolts for this: just get some mild steel ones at the hardware store.
gene bender
PostPosted: Fri Nov 16, 2012 4:21 am    Post subject: Re: head straight Reply to specific post Reply with quote
You put the headbolts in before putting the head on cause how are you going to tighten them if the head is on first there nothing but threads sticking above the head after the head is installed and putting a pipe wrench will destroy those threads so you install the headblots first.Make sure the threads in the block are clean and also the threads on the headbolts are clean. Use some lube when installing the headbolts.
John G. Hasler
PostPosted: Fri Nov 16, 2012 5:59 am    Post subject: Re: head straight Reply to specific post Reply with quote
> installed
You describe studs, not bolts. In that case I agree with you. No dowels are needed.
Hattrick
PostPosted: Fri Nov 16, 2012 8:44 am    Post subject: Re: head straight Reply to specific post Reply with quote
I agree with Gene. YOu need to put the studs in the block and get them tightened up before you place the head. Once this is done this will gove you what you need to line it up. I would also recommend copper seal on the head gasget as these can tend to leak. It is to pain to get the head back of and get it cleaned up again but does a great job getting it sealed.
TUCKAWAY
PostPosted: Fri Nov 16, 2012 3:37 pm    Post subject: Re: head straight Reply to specific post Reply with quote
bolts where in block,copper coated gasket,placed head on block I guess it went to easy. just making sure nothing else to line up. thanks for all help. tuck
