| Author |
Message |
Darryl 2M's New User
Posted: Thu Nov 15, 2012 7:15 pm Post subject: TD6 polarity |
Just got a new td6 crawler with no battery. Guy didn't remember if it was postive or negative ground. I KNOW someone knows! You guys never fail me. thanks in advance. i know its 12 volt... |
| Back to top |
gusbratz Regular
Posted: Thu Nov 15, 2012 8:05 pm Post subject: Re: TD6 polarity |
it dont matter, put a battery in - ground manner. then take a jumper wire from your + on the battery or the B on the voltage regulator and touch it to the G terminal on the voltage reg. just tap it, a little spark is all it takes. this will polerize the genny and make it charge the battery.
http://web.utk.edu/~tprather/FoothillsTractorClub/TechTips/PolarizeGenerator.html
| Back to top |
jm. Tractor Expert
Posted: Fri Nov 16, 2012 6:48 pm Post subject: Re: TD6 polarity |
Follow his directions but go on and use Negative ground then you will be able to jump from other common things. You will just be better off. Your amp guage MAY read backwards, can,t remember. |
| Back to top |
Darryl2M's Guest
Posted: Sat Nov 17, 2012 5:46 pm Post subject: Re: TD6 polarity |
thanks you saved me from some headaches! didn't want to fry anything by doing the wrong thing.... |
| Back to top |
Darryl 2Ms Regular
Posted: Sat Nov 17, 2012 5:49 pm Post subject: Re: TD6 polarity |
yeah ...you are so right about being able to take a jump from something else. negative ground just makes things easier. i was just afraid of frying the generator or regulator. thanks alot |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
