Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Standard BLOCK Bore C113 and C123
equeen
PostPosted: Thu Nov 15, 2012 8:34 pm    Post subject: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
Can anyone please advise of the factory block bore for engines:
C-113
C-123
Also, was block number 354898R1 bored for C-113 and the same block factory bored for C-123?
Thanks.
stumper
PostPosted: Thu Nov 15, 2012 10:52 pm    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
C-113 is 3" and the c-123 is 3 1/8" , stumper
stumper
PostPosted: Thu Nov 15, 2012 10:56 pm    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
C-113 is 3" and the c-123 is 3 1/8" of witch both these engines have wet sleeves in them , stumper
ShaggyM
PostPosted: Fri Nov 16, 2012 3:09 am    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
Both have wet sleeve's.
Some C 123's also had 3 in bore.
You can put a 3 1/8 bore in a C 113
and a 3 1/4 bore in a C123
gene bender
PostPosted: Fri Nov 16, 2012 4:06 am    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
You need the part # on the block as later blocks would accecpt 3 1/4 sleeves olser blocks were the same with the exception of having a place for the hy pump. You need to measure the bottom where the sleeve seats to see which block you have it will also have the place for the hy pump. Side note a 113 block will take larger sleeves making it 123cu in.
teddy52food
PostPosted: Fri Nov 16, 2012 6:37 am    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
898 block is 123 or the larger of the 2.
CNKS
PostPosted: Fri Nov 16, 2012 7:51 pm    Post subject: Re: Standard BLOCK Bore C113 and C123 Reply to specific post Reply with quote
The 898 block was initially sleeved with thicker sleeves to give only 113 cu in until the Super A1 and Super C appeared. Then the cu in went to 123. The 898 blocks in the 113 and 123 were identical and had identical bores, only the sleeves were different. The current engine kits have sleeves that allow 134 cu in without increasing the size of the original bore. The 898 block is not to be confused with the original C113 block, which will accept later sleeves no larger than those giving 123 cu in without boring.
