| Author |
Message |
Grabatire Regular
Posted: Thu Nov 15, 2012 9:52 pm Post subject: WD9 Dual Exhaust |
There's an ad on the YT Photo Ads wherein the seller claims the dual exhaust on a WD9 are 'factory'. Now it could well be that a factory did build that set up, but I wasn't aware of IHC ever offering that as an option, and it doesn't show up in any parts book that I have.
Anybody know? |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5457 Location: SE Wisconsin
Posted: Fri Nov 16, 2012 4:22 am Post subject: Re: WD9 Dual Exhaust |
Huh, so there are two cyls feeding one exhaust pipe? In line??? I have never seen such a thing and it isn't in the parts book. I would like to learn more about it. |
| Back to top |
mkirsch Tractor Guru
Posted: Fri Nov 16, 2012 5:07 am Post subject: Re: WD9 Dual Exhaust |
Frankly, a lot of people claim things are "factory." He probably claims the paint job is "factory" too...
| Back to top |
D Slater Tractor Expert
Posted: Fri Nov 16, 2012 5:24 am Post subject: Re: WD9 Dual Exhaust |
Since the center cylinders share the same exhaust port in the head. From the placement of the mufflers I think the manifold is open to all cylinders with just another outlet added. |
| Back to top |
Bob M Tractor Guru
Posted: Fri Nov 16, 2012 7:23 am Post subject: Re: WD9 Dual Exhaust |
Never seen anything like that - no way it came from the factory. Further a dual exhaust on a WD9 makes no sense since the engine has THREE exhaust ports (middle 2 cylinders share the center port as sflem849 and D Slater point out).
I suspect rather that tractor has had a tee fitting installed atop the stock manifold with the tee's run outlets feeding the mufflers.
Incidentally I once ran across a UD9 power unit (same engine as the WD9) in a Bucyrus dragline crane with a straight-piped triple exhaust. It had obviously been "home built" to replace the original 3-leg manifold. |
| Back to top |
jim warehime Regular
Posted: Fri Nov 16, 2012 10:39 am Post subject: Re: WD9 Dual Exhaust |
Its kinda hard to tell in the photo but don't the muffles look to be on the opposite side of the tractor, don't the 9 series use the same exhaust location as the 6 series and md's? Jim. |
| Back to top |
Matt E. Regular
Joined: 04 Dec 2011 Posts: 134 Location: Springfield, MO
Posted: Fri Nov 16, 2012 12:09 pm Post subject: Re: WD9 Dual Exhaust |
They are on the right side, litterally. You can see the rear muffler is on the side closest to you, in front of the hood bulge for the guages. That would be correct for a diesel model. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18457 Location: St. Cloud, MN
Posted: Fri Nov 16, 2012 12:40 pm Post subject: Re: WD9 Dual Exhaust |
As far as I know all gas start diesel run engines from IH were manifolds on the right. Jim |
| Back to top |
heavyhaulertoo Regular
Posted: Fri Nov 16, 2012 5:04 pm Post subject: Re: WD9 Dual Exhaust |
Maybe he thinks hes got d18 motor ha. |
| Back to top |
charlieu Regular
Posted: Sat Nov 17, 2012 7:33 pm Post subject: Re: WD9 Dual Exhaust |
Here are a couple pictures of a TD18A, that I just finished repairing. This had factory dual exhaust. Three cylinders feeding exhaust to each muffler.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
