Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1020 input shaft
Post new topic    Yesterday's Tractors Forum Index -> John Deere
bluedog
PostPosted: Fri Nov 16, 2012 4:41 pm    Post subject: 1020 input shaft Reply to specific post Reply with quote
Can somebody help me out? I've got a 1020 gas tractor that leaks hydraulic oil out of the bottom of the bell housing when i shut it off. I believe it's the seal on the transmission input shaft. I need the tractor and want to do a one day job,so I want the parts here before I split it.
Problem is that the JD PArts website is a little vague on this. I pulled up the powertrain section,then number 10 clutch disconnect and flywheel. As far as I can tell,I need number 8,part number AF1934R. Does that look right? What about number 9,part number T22178 ? It says washer. Is that a large O ring/gasket for the housing that holds the seal?
Also,it looks like that seal goes in from the back. Does that number 10 part that they call a support have to come out?
Thanks.
Tx Jim
PostPosted: Sat Nov 17, 2012 4:10 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
The parts you looked up are for a tractor with the hyd reverser. Does your tractor have a hyd reverser? What type pto does your tractor have (trans driven,continuous[dual stage clutch] or hyd independent] ??
bluedog
PostPosted: Sat Nov 17, 2012 6:46 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
No reverser,live PTO,not independant,two stage clutch type. Has the main clutch and the PTO clutch in the flywheel. 1969 model. that part's site isn't labeled real well.
Tx Jim
PostPosted: Sat Nov 17, 2012 9:31 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
Years of employment at a JD dealership will help you navigate JDparts.com Wink parts key #2 AT21780 SEAL
bluedog
PostPosted: Sat Nov 17, 2012 9:33 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
Thanks. Can that be changed from the front after the split? Or is there more to it than that?
Tx Jim
PostPosted: Sat Nov 17, 2012 9:58 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
Parts key #2 can be changed just by splitting between clutch housing & engine but if parts key #10 is leaking then that's a different story.
bluedog
PostPosted: Sat Nov 17, 2012 5:32 pm    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
What do you think the odds would be that it would be the other seal? The number 10?
Tx Jim
PostPosted: Sun Nov 18, 2012 4:14 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
I think the % for having to replace #10 would be very low.
bluedog
PostPosted: Sun Nov 18, 2012 7:15 am    Post subject: Re: 1020 input shaft Reply to specific post Reply with quote
OK,thanks a lot for your time. I'll get that number 2 and hope that's it when I get it apart.
