| Author |
Message |
Hayfarmer Long Time User
Posted: Fri Nov 16, 2012 5:03 pm Post subject: 320 hydraulic pump |
I hooked up wood splitter to 320. Used line from pump to 3 point, in from pump, out to 3 point. Same place as loader hooks to my 430 and have used 430 on wood splitter. Was just moving ram back and forth no wood being split, hydraulic pump developed a crack in center section. did I do it or was it a weak spot in pump. Has done fine on 3 point before. Also what pumps will fit? is it the smae as M or 40?
Thanks for any help |
| Back to top |
Dave H Long Time User
Posted: Fri Nov 16, 2012 7:38 pm Post subject: Re: 320 hydraulic pump |
Did you use an open center valve on the splitter? |
| Back to top |
M-MAN Long Time User
Posted: Fri Nov 16, 2012 9:54 pm Post subject: Re: 320 hydraulic pump |
Up to serial no# 330301 uses the same pump as a 40. After that it is the same pump as a 420. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13091 Location: Coyote Flats,Tx
Posted: Sat Nov 17, 2012 4:24 am Post subject: Re: 320 hydraulic pump |
If log splitter valve was an open-center then I think the log splitter valve relief valve was set higher than pump was designed. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23611 Location: in front of computer
Posted: Sat Nov 17, 2012 5:51 am Post subject: Re: 320 hydraulic pump |
Either no relief valve in circuit, relief valve pressure too high or used a closed Center valve. |
| Back to top |
F-I-T Tractor Guru
Joined: 27 Feb 2002 Posts: 8447 Location: United States
Posted: Sat Nov 17, 2012 5:59 am Post subject: Re: 320 hydraulic pump |
| buickanddeere wrote: | | (quoted from post at 06:51:57 11/17/12) Either no relief valve in circuit, relief valve pressure too high or used a closed Center valve. |
But he said that the splitter worked fine on his 430, so it really can't be an incorrect splitter valve config, right? |
| Back to top |
Posted: Sat Nov 17, 2012 6:34 am Post subject: Re: 320 hydraulic pump |
He has a loader on the tractor . Odds are the connection is
made down stream of the loader valve and is protected by the
relief in the loader valve. |
| Back to top |
Posted: Sat Nov 17, 2012 10:11 am Post subject: Re: 320 hydraulic pump |
Been thinking more about this. 430 has loader so wood splitter vaove would be down stream of loader valve. On 320 until log splittervalve was moved it would be against relief valve in 3 pt housing but when splitter valve was activated the only relief valve would be in splitter valve, is that correct? Is center section crack what usually results from pump trying to pum too much pressure? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
