| Author |
Message |
mschwartz Guest
Posted: Fri Nov 16, 2012 7:17 pm Post subject: hand crank? |
Could anyone tell me if the starting cranks were the same for the F-series tractors and the farmall H and M? I know that some were longer for the wide front axle. Mostly wondering if the slot in the end for the starting pin coming out of the bolster was in line with the bend in the handle or was 90 degrees off? Have some that are both ways but not sure if they have been modified or not. Thanks, Mike |
| Back to top |
blunted Regular
Posted: Fri Nov 16, 2012 7:29 pm Post subject: Re: hand crank? |
you would think thay would be straite, if im getting you rite. i know my a has the crank, but is bigger in diamater for the balster in front of my sc.. |
| Back to top |
Mark Poss Regular
Posted: Sat Nov 17, 2012 4:24 am Post subject: Re: hand crank? |
My handcrank for my H fits my F-20 |
| Back to top |
Badger bob Long Time User
Posted: Sat Nov 17, 2012 5:24 am Post subject: Re: hand crank? |
I have some cranks around hear that are to small ( hole in the end) to fit my f20 i though that thay were for the m or h . Bob |
| Back to top |
Arnold Layne Regular
Posted: Sat Nov 17, 2012 8:22 am Post subject: Re: hand crank? |
The coupling on an H and M crank is smaller than an F series, the F will work on an H or M but not vice versa. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18228 Location: St. Cloud, MN
Posted: Sat Nov 17, 2012 11:24 am Post subject: Re: hand crank? |
I can give an answer that works!!
When put on the crank drive, and pushed in to engage the crank, the handle of the crank should be at the bottom, or 15 to 20 degrees clockwise from bottom. (assuming the engine was shutoff and allowed to stop naturally) inline 4 cylinder engines stop with the pistons about 1/2 way in the bores. Pulling up is the only safe (ish) way of cranking, and if the pin placement was incorrect, the handle would be in an unsafe position. Jim |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
