| Author |
Message |
Steve-Maine Regular
Posted: Fri Nov 16, 2012 11:35 pm Post subject: Railroad station sign |
Has anyone made a Railroad Station sign with the name of the town ? I would like to make one up here in Maine. They were blue with white letters. I live next to RR and think it would look neat over the barn door. Thanks for any help. |
| Back to top |
Stephen Newell Tractor Expert
Posted: Sat Nov 17, 2012 5:17 am Post subject: Re: Railroad station sign |
If this is what you mean it's just stenciled sheet metal. Depending on the duribility you want it could be done with rattle can paint through a 2k urethane.
| Back to top |
Steve-Maine Regular
Posted: Sat Nov 17, 2012 5:23 am Post subject: Re: Railroad station sign |
The local ones here in Maine where blue with white letters, no border and look like they might have been porcelain. I would like to make one out of metal or wood but need a shiny finish. Thanks |
| Back to top |
S.Crum Tractor Expert
Posted: Sat Nov 17, 2012 5:56 am Post subject: Re: Railroad station sign |
Any town that had tracks had a station and as such station aigns. These were not under any standardized goverment control, as such they were unique to railroad they served. Check with some of the folks in your town, somebody might have a picture of the station and even some recollection of the signage color. They are neat and not difficult to reproduce. |
| Back to top |
PJH Tractor Expert
Posted: Sat Nov 17, 2012 6:31 am Post subject: Re: Railroad station sign |
Here's a link to a pic of one. Pretty simple. A long way from Maine though - Tamms, Illinois - restored depot - now city hall.
Paul
Depot sign
| Back to top |
Jim in Ma. Tractor Expert
Joined: 30 Jul 2007 Posts: 1860 Location: Newbury Ma. 01951
Posted: Sat Nov 17, 2012 7:07 am Post subject: Re: Railroad station sign |
For a real shiny look, Could you find a piece of plate glass the size and shape you need. Paint on the back stencle the name first and then the back ground. there is a name for that style but don't remember it.
You could try that with plexie but I'm not sure how it would stand up in the weather. |
| Back to top |
PJH Tractor Expert
| Back to top |
Wardner Tractor Guru
Joined: 14 Dec 1999 Posts: 5373 Location: Tewksbury, MA 01876
Posted: Sat Nov 17, 2012 8:24 am Post subject: Re: Railroad station sign |
I went to a factory auction 30 years ago in eastern Mass where they made porcelain signs. Probably one of the last in the country. They had a huge oven that had to run 24/7. They couldn't shut it down because it took too long to get it to operating temperature. It looks like the Bangor and Aroostock RR chose to use a cheaper alternaive.
There is a guy on eBay who will make vinyl on aluminum signs. I have a standing search using my name "Wardner". Several times a year, eBay will send me an alert for a town sign lettered "Wardner, ID)". The signs are less than $20. The town was named after my great grandfather around 1890. |
| Back to top |
Posted: Sat Nov 17, 2012 8:40 am Post subject: Re: Railroad station sign |
This tractor was done with Dupont Nason which is a 2k urethane. I think it's pretty shinny and it could also be clear coated if more is needed. I cut the stencil for the lettering from typing paper I printed on my computer. After letting the yellow dry good I applied the stencil with a spray adhesive applied to the back of the stencil.
| Back to top |
Posted: Sat Nov 17, 2012 8:47 am Post subject: Re: Railroad station sign |
Dang, how close are you to Tamms. I'm related to the Newells there. |
| Back to top |
Posted: Sat Nov 17, 2012 9:08 am Post subject: Re: Railroad station sign |
If you wamt to get fancy, look into "glue chipped glass". You need a small sandblaster, sheet rubber stencil material, and old-time animal furniture glue flakes. Best results if blasted lightly. There is probably how-to info on the web.
| Back to top |
PJH Tractor Expert
Posted: Sat Nov 17, 2012 9:15 am Post subject: Re: Railroad station sign |
Stephen - I'm about 60 miles north - closer to Chester, IL. |
| Back to top |
Old Bob Regular
Posted: Sat Nov 17, 2012 4:01 pm Post subject: Re: Railroad station sign |
Where can you get the rubber stencils cut?? |
| Back to top |
Posted: Sat Nov 17, 2012 5:11 pm Post subject: Re: Railroad station sign |
Sign shops, grave stone artisans, maybe tat-too shops. Actually anyone who is an artist and whose work you like. You shouldn't call your local surgeon.
I wouldn't be surprised if the machines that cut vinyl could be outfitted to cut the 1/32" sheet rubber.
My local industrial sandblast equipment jobber sells the rubber. They probably know some people. |
| Back to top |
gtractorfan Long Time User
Joined: 26 Sep 2011 Posts: 1171 Location: Van Wert, Ohio
Posted: Sun Nov 18, 2012 12:32 pm Post subject: Re: Railroad station sign |
Couldn't resist adding this train station photo although there's no signs showing. Glad I got this picture 30+ years ago before the tracks and station were removed. There's another set of tracks crossing these on behind the station. When I see a place like this I wish there'd be a way to learn all the stories that went with the place. This is at Ohio City, Ohio.
| Back to top |
