| Author |
Message |
William Fissell Long Time User
Posted: Sat Nov 17, 2012 5:42 am Post subject: 640 Gas Line Routing? |
Can someone post a picture of how the gas line is
routed on a 640? I am replacing the inline fuel
filter with a sediment bowl and new gas line, but
I can;t see how to get it there without either a
crazy long path, or running right on top of the
exhaust manifold.
thanks |
| Back to top |
JMOR Tractor Guru
Posted: Sat Nov 17, 2012 6:00 am Post subject: Re: 640 Gas Line Routing? |
| William Fissell wrote: | (quoted from post at 09:42:51 11/17/12) Can someone post a picture of how the gas line is
exhaust manifold.
thanks | not sure where along length of line that you are asking, but on side of engine it passes between block/head & the manifolds |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50677 Location: Lake of the Ozarks area of MO
Posted: Sat Nov 17, 2012 6:57 am Post subject: Re: 640 Gas Line Routing? |
The factory fuel line ran as JMOR says and is behind the manifold and it also has a part of it that was rubber line but made just for the 600/600/801/601 series tractor. I have replaced more then one and used brake line and ran it so it went forward of the manifold so as to keep it cooler |
| Back to top |
Kurt-NEPA Long Time User
Joined: 05 Mar 2009 Posts: 747 Location: Tunkhannock, PA
Posted: Sat Nov 17, 2012 12:54 pm Post subject: Re: 640 Gas Line Routing? |
Couple of Pictures - Hope you can see the tube.
The fuel line goes forward out of the shut off valve for about 6-8 inches, then makes a 180 degree bend and back the 6-8 inches. Then it takes a 90 degree bend and goes down behind the muffler and through the manifold to attach to the back side of the sediment bowl.
You need take the tank off and attach the tube to the shut off valve. I goes on a slight angle. Then lower the tank down and thread through the manifold and attach to the sediment bulb. A second set of hands really helps.
BTW, the rubber tube old mentioned - I think that was on later 601 series tractors. I think all the 600 series used steel tube all the way. I know my 55 - 660 is all steel
Hope this makes some sense - kinda hard to put into words and harder yet to get a good picture of. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
