Author |
Message |
Fritz Maurer Long Time User
Posted: Sat Nov 17, 2012 5:56 am Post subject: Mouse pee |
I had some mice living in the console in my 9700. Got the nest out ok, but every time the hydraulics warm up, I get the stench. I thought it would go away after a couple years but it never does. All the air fresheners do is chloroform me all the time they're working, then the smell comes back when they're worn out. Got a few $$$ in new interior pieces, and I want this smell gone before I install them. Thanks, Fritz |
Back to top |
Chuckles46 Regular
Posted: Sat Nov 17, 2012 6:19 am Post subject: Re: Mouse pee |
try an ozone generator in it for a while. Works on smokey car interiors |
Back to top |
Michael Soldan Tractor Expert
Joined: 14 Aug 2007 Posts: 1831 Location: Exeter Ontario
Posted: Sat Nov 17, 2012 6:24 am Post subject: Re: Mouse pee |
I guarantee this will work Fritz. Buy a couple of big bottles of soda water,the kind you mix in your scotch! Flood the area with this carbonated soda water ,use a mist bottle if you have to. The dissolved soda in the drink removes the smell permanently.I have had the best results with this. This works for pet odors around litter boxes as well. We did a job at a cottage that had mice in it.We couldn't stand the smell when the place got warm,used some of this and ended the smell.We finished the renovation without further incident...good luck |
Back to top |
stumper Regular
Posted: Sat Nov 17, 2012 9:37 am Post subject: Re: Mouse pee |
had that in an old pickup heater box had two wash it out with bleach & water it was a pain in the AA$$ but it took care of 95% of the smell , it was nasty, stumper |
Back to top |
Kenneth R Ohnstad Regular
Posted: Sat Nov 17, 2012 9:49 am Post subject: Re: Mouse pee |
most likely afterbirth, that is worse.
k |
Back to top |
James Babcock Regular
Posted: Sat Nov 17, 2012 10:45 am Post subject: Re: Mouse pee |
Vinegar in a spray bottle. |
Back to top |
dave2 Guest
Posted: Sat Nov 17, 2012 1:24 pm Post subject: Re: Mouse pee |
This stuff is real good and works instantly.....
http://www.jefferspet.com/x-o-odor-neutralizer-plus/p/0030272/
Doing hooves the other day and the poo and that hoof smell just wouldn't wash off. Didn't have any of this stuff mixed so grabbed a bottle of sanitizer spray that is rubbing alchol and lemon juice and doused my hands. Got rid of the oder just fine, maybe that'll work for you. If you mix your own, just a spray bottle and a tablespoon of lemon juice to maybe a cup of alcohol. |
Back to top |
Dick2 Tractor Guru
Posted: Sat Nov 17, 2012 3:18 pm Post subject: Re: Mouse pee |
Odo-Ban is available at Home Depot and Sam's club. It's a concentrate; just mix it into a spray bottle at recommended ratio. Resulting odor is not offensive, but you will probably need to get the mixture into the source area to be most effective. |
Back to top |
redtom Tractor Expert
Posted: Sat Nov 17, 2012 6:02 pm Post subject: Re: Mouse pee |
Had just a few droppings in the shallow heat duct that runs under the floor of my 5th wheel camper. I tried all the usual stuff but until I made up a log "canon swab" of rag on a wire and ran beach up and down the duct, it smelled. So, unless you can bleach it you may be screwed. I have had some luck on mouse smell with a product called "skunk away" which I had to spray on my cat when it got skunked. I got it from my vet. |
Back to top |
