Ammeter Suddenly Shows Charging
F4RM@11
PostPosted: Sat Nov 17, 2012 2:35 pm    Post subject: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
After getting the SM started again following a carb rebuild, I turned to the electrical system to troubleshoot the lack of charging. The VR output had been adjusted and the gen inspected by an auto electric shop - both had a clean bill of health.
The ammeter showed a slight discharge with the ignition switch on and the needle didn't move with changes in engine speed. Following Bob's troubleshooting flow chart, I made it through to the last step before the ammeter began showing a charge.
When I jumpered the BAT and GEN terminals at the regulator, the ammeter suddenly began showing a charge and continued to do so afterward. The needle moved appropriately with engine speed.
I'm curious as to why a charge on the ammeter suddenly began to show after making this brief circuit. The battery was fully charged after I returned to the shop as the trickle charger indicated so.
mkirsch
PostPosted: Sat Nov 17, 2012 2:45 pm    Post subject: Re: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
Shut it down and start it up again. Does it still charge?
I had the same problem last year, and it was a bad regulator.
F4RM@11
PostPosted: Sat Nov 17, 2012 2:50 pm    Post subject: Re: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
mkirsch wrote:
(quoted from post at 15:45:36 11/17/12) Shut it down and start it up again. Does it still charge?
Yes, I had it shut down a few times today, one of which was for 30 mins or so. The ammeter continued to show a charge after each start. I'm not complaining - just curious to understand what happened.
gbs
PostPosted: Sat Nov 17, 2012 4:49 pm    Post subject: Re: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
you polarized the generator
F4RM@11
PostPosted: Sat Nov 17, 2012 5:11 pm    Post subject: Re: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
Embarassed I feel silly for not knowing that since it says right on Bob's troubleshooting flow chart. Duh! Thanks.
Bob M
PostPosted: Sat Nov 17, 2012 5:13 pm    Post subject: Re: Ammeter Suddenly Shows Charging Reply to specific post Reply with quote
Your generator was likely polarized backward; jumpering BAT and GEN terminals fixed that.
Could also however be an intermittant problem involving the regulator ground - especially if the regulator is in the stock location bolted on the front of the steering wheel stanchion. (The Super M is notorious for VR grounding problems here.)
Suggest running a #14 ground wire from the regulator base to a GOOD frame ground - ideally where the grounded battery cable is attached.
