| Author |
Message |
Douglas Miner Regular
Posted: Sun Nov 18, 2012 8:36 am Post subject: Ford 4000 4 cyl. Gas steering trouble |
I switched the two steering lines from the column
to the ram on the side of my tractor with the
inching pedal. Now it does not want to turn. Do I
need to bleed the air out of the ram? |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1682 Location: Southeast PA
Posted: Sun Nov 18, 2012 4:55 pm Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
Not sure what you mean by "I switched the two steering lines from the column to the ram on the side of my tractor with the inching pedal."
If you replaced them with new lines, are you sure that you hooked the same way the old ones were connected? If you reversed the connections, then the ram on the left side of the tractor will be trying to move the steering in the opposite direction as the ram on the right side and the result will be no movement.
Try disconnecting one end of each of the rams from the steering linkage and turning the wheel. That way you'll see if the rams are moving, and which way they're moving as you turn the steering wheel.
If they are hooked up correctly, then steering from full stop left to full stop right back and forth a few times should bleed any air out of the system. Have you checked the fluid level in the reservoir? |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12437 Location: Twin Cities
Posted: Sun Nov 18, 2012 6:00 pm Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
Sean is correct. Try reversing the lines on that side and see what happens.
Do Not force the wheel against the hudraulics.
You will break the little springs in the steering actuator block in the steering column and then you'll have a bunch more questions.
Inching pedal is on the Port side of the tractor. |
| Back to top |
Larry NCKS Tractor Guru
Joined: 23 Dec 2001 Posts: 3711 Location: Washington, KS/Lincoln, NE
Posted: Mon Nov 19, 2012 5:32 am Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
Now-if us lay folk only knew what "Port side" meant!
| Back to top |
Posted: Mon Nov 19, 2012 3:25 pm Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
Sorry Larry.
If ships had inching pedals I could have helped you out as to as to the port and starboard. |
| Back to top |
Posted: Sun Nov 25, 2012 2:15 am Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
I switched the lines and the steering appeared to be working. I then topped of the reservoir and now the wheels only turn slightly before I get a squeal like the steering is at the end of its travel range. I tried to disconnect the front end of the rams but the spindles are stuck in place. Is there a trick for getting them out other than a bigger hammer. Thanks |
| Back to top |
Posted: Mon Nov 26, 2012 4:23 am Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
I switched the lines and the steering appeared to be working okay. I then topped off the reservoir and now the steering only moves a few inches then stops. I turn the wheel a little and I get a squeal from the steering pump. I tried to disconnect the steering rams but the spindles are stuck in place. Is there a trick for getting them out other than a bigger hammer? Thanks Doug |
| Back to top |
Posted: Mon Nov 26, 2012 10:39 am Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
You still haven't explained what you mean by "I switched the lines". |
| Back to top |
Posted: Mon Nov 26, 2012 10:49 am Post subject: Re: Ford 4000 4 cyl. Gas steering trouble |
Sorry for not clarifying switched. I should have
said replaced 2 lines. I ended up bleeding the
lines at the steering ram and the steering works
fine now. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
