| Author |
Message |
Clint(oh) Regular
Posted: Sun Nov 18, 2012 3:17 pm Post subject: 801 hydraulic lift |
A few months ago I posted about how my 801 Powermaster three point hitch abruptly stopped working. There were a number of people who offered advise and today I finally had a chance to look into the problem. Turns out that after looking into the fill hole I see some linkage disconnected, I removed the top cover and the connecting rod to the piston is disconnected from both ends. So obviously I need to obtain a new pin, but the question is why/how did the pin come out in the first place? And then I notice another small rod extending from some linkage adjacent to the piston, not sure if this is something else broken or if it is supposed to look this way. If I get a chance this week I will post a picture and try to clarify what I am trying to describe. |
| Back to top |
Kurt-NEPA Long Time User
Joined: 05 Mar 2009 Posts: 737 Location: Tunkhannock, PA
Posted: Mon Nov 19, 2012 4:05 am Post subject: Re: 801 hydraulic lift |
Here's a picture of how it should look, maybe it will help.
| Back to top |
Clint(oh) Regular
Posted: Mon Nov 19, 2012 4:47 am Post subject: Re: 801 hydraulic lift |
Thank You, that answers some a question, at the end
of the cylinder is a short rod coming from the
linkage toward the cylinder and I see that is
correct. Now I have to locate the pin that holds the
connecting rod in place. |
| Back to top |
Dean Tractor Guru
Posted: Mon Nov 19, 2012 6:52 am Post subject: Re: 801 hydraulic lift |
Did the piston come out of the cylinder? If not, the "short rod" did its job.
In any event, always replace the cam follower pin and Piston O-ring and back-up washer anytime the lift cover is removed. After doing this, readjust the linkage using the alternative (special tools not needed) procedures in the FO-20 manual. If you find insufficient threads on the turnbuckle to achieve proper draft control adjustment, replace the draft control fork.
You should thoroughly clean the sump and replace the hydraulic oil.
Dean |
| Back to top |
Clint(oh) Regular
Posted: Thu Nov 22, 2012 9:11 am Post subject: Re: 801 hydraulic lift |
Ok, Got the problem almost resolved, however there is a concern. The pin holding the connecting rod in place is gone, I cant find it anywhere, I have drained the case and looked all around inside, looked all over the top cover. Is there any possibility that it could have traveled into the transmission or the axle. I would really like to find it before it damages something else. You would think that a 5/16" x 2 1/8" pin would turn up quite easily. |
| Back to top |
JMOR Tractor Guru
Posted: Thu Nov 22, 2012 9:51 am Post subject: Re: 801 hydraulic lift |
| Clint(oh) wrote: | | (quoted from post at 13:11:08 11/22/12) Ok, Got the problem almost resolved, however there is a concern. The pin holding the connecting rod in place is gone, I cant find it anywhere, I have drained the case and looked all around inside, looked all over the top cover. Is there any possibility that it could have traveled into the transmission or the axle. I would really like to find it before it damages something else. You would think that a 5/16" x 2 1/8" pin would turn up quite easily. | not into transmission or axle on that model. I don't know if into suction line is possible or not...someone probably knows. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
