| Author |
Message |
Bobby 9891 Regular
Posted: Sun Nov 18, 2012 7:10 pm Post subject: oil pressure |
Just bought a 49 "C" & was wondering what is normal oil pressure ?? The gauge shows about 3-4 pounds of pressure @ working rpm"s & nothing @ idling. Runs good & seems to have power but was concerned- should I be ?? Thanks Bobby |
| Back to top |
Justin SE IOWA Long Time User
Joined: 21 Sep 2010 Posts: 557 Location: Oskaloosa Iowa
Posted: Sun Nov 18, 2012 7:40 pm Post subject: Re: oil pressure |
Nope dont be worried. All those ole AC's have low oil pressure |
| Back to top |
Dick L Tractor Guru
Posted: Mon Nov 19, 2012 3:24 am Post subject: Re: oil pressure |
Low oil pressure on these engines has nothing to do with the amount of oil at the bearings. The oiling of the bearings comes from a rotating camshaft forcing the oil out to the bearings. |
| Back to top |
Aaron SEIA Long Time User
Posted: Mon Nov 19, 2012 4:52 am Post subject: Re: oil pressure |
Might want to make sure it has the correct oil filter. For a while some of the new replacements were using a pleated paper media that led to low oil pressure. Media in the filter should be spun cotton, I know the Fram C159 is correct. Not sure on others. My personal opinion is 3-4 working and 0 at idle is too low.
AaronSEIA |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50454 Location: Lake of the Ozarks area of MO
Posted: Mon Nov 19, 2012 7:46 am Post subject: Re: oil pressure |
2 common reasons for that problem are incorrect oil filter I use WIX57011 filters or the filter tube that goes up into the filter being missing due to the fact it stayed on the filter when a person changed oil |
| Back to top |
Bobby 9891 Regular
Posted: Tue Nov 20, 2012 6:52 am Post subject: Re: oil pressure |
I changed the oil filter-because it was painted over but it had the fram C159 on it & the tube was there. The gauge looks new. |
| Back to top |
old Tractor Guru
Posted: Tue Nov 20, 2012 7:23 am Post subject: Re: oil pressure |
My have a bad new gauge or the wrong gauge. The A/C oil systems are low pressure systems so having a gauge to reads say 0-30 is incorrect and will give false readings so you need the correct A/C type gauge. Even when brand new the engine is lucky to have mush if any more then 15PSI |
| Back to top |
Dave DelDebbio Regular
Posted: Tue Nov 20, 2012 2:43 pm Post subject: Re: oil pressure |
I had to clean out the tube from the filter to gauge. when I got one of my tractors, seamed the previous owner didnt like changing oil and the tube had gunk in it.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
