| Author |
Message |
brian stanek Regular
Posted: Sun Nov 18, 2012 8:22 pm Post subject: 880 clutch |
clutch problems in 880 do believe it has the power multiplier. at least there is a shifter that is not ever used. is it possible to get a pic of what im up against or download some info.probably never work on one again so really dont want to buy a manual.i shifts not bad in either the lower range or higher range but from one to the other has to be shut down and started in gear. |
| Back to top |
sdc eastern ia. Regular
Posted: Mon Nov 19, 2012 6:26 am Post subject: Re: 880 clutch |
Pretty straight foreward actually. Remove the cover if it's still on so you can see the clutches. Remove the springs, bolts (count the shims), make a diagram of the placement of clutches and steels. Reverse to assemble. |
| Back to top |
J. Schwiebert Guest
Posted: Mon Nov 19, 2012 7:24 pm Post subject: Re: 880 clutch |
Also look at the old posts that you asked about the clutch. Remember safety first. You will need a lift that will raise a 1000 pounds when you remove the engine. First thing to do is remove the PTO shaft!.I would guell your pilot bearing is bad! |
| Back to top |
Posted: Mon Nov 19, 2012 7:45 pm Post subject: Re: 880 clutch |
so it looks like you dont split the tractor but instead take out the engine, but first the pto shaft am i correct? |
| Back to top |
J. Schwiebert Guest
Posted: Tue Nov 20, 2012 3:43 am Post subject: Re: 880 clutch |
Yes |
| Back to top |
Posted: Tue Nov 20, 2012 3:59 am Post subject: Re: 880 clutch |
thanks for the info its in the shop so now aemed with that info i know more what to look for. |
| Back to top |
Posted: Tue Nov 20, 2012 3:49 pm Post subject: Re: 880 clutch |
so in getting somewhat into the clutch area, all takup is used on clutch pedal rod, looks like the grease line has rubbed on pressure plate. is there any external adjustment on the pressure plate, or is time for new parts? with clutch fully depressed tractor still wants to move somewhat. when you say cover has be removed do you mean main clutch cover, because i removed the tin cover over the pto? |
| Back to top |
Posted: Tue Nov 20, 2012 8:26 pm Post subject: Re: 880 clutch |
now that i think about it must be the power booster that has the tin cover. there was no push rod to the throughtarm. |
| Back to top |
J. Schwiebert Guest
Posted: Wed Nov 21, 2012 6:34 am Post subject: Re: 880 clutch |
You need to remove the part where the tin PTO cover was attached (4 -3/8 inch cap screws). This is the clutch cover for the PTO. Then behoind the PTO clutch will be 3-3/8 inch cap screws. They need to be removed and then use a wrecking bar and pop the clutch assembly and the long PTO shaft from the tractor. |
| Back to top |
J.Wondergem Tractor Expert
Joined: 05 Mar 2009 Posts: 2009 Location: Rockford, Mi
Posted: Wed Nov 21, 2012 6:39 am Post subject: Re: 880 clutch |
| J. Schwiebert wrote: | | (quoted from post at 10:34:17 11/21/12) You need to remove the part where the tin PTO cover was attached (4 -3/8 inch cap screws). This is the clutch cover for the PTO. Then behoind the PTO clutch will be 3-3/8 inch cap screws. They need to be removed and then use a wrecking bar and pop the clutch assembly and the long PTO shaft from the tractor. |
You must do as John says before you try anything on the tractor clutch, because the PTO shaft runs through the tractor clutch into the flywheel. |
| Back to top |
Posted: Wed Nov 21, 2012 12:19 pm Post subject: Re: 880 clutch |
sorry i guess i am just not getting the picture. john are you talking about the pto shaft behind the tractor? that must mean draining all oils.i dont figuire it out will post a pic. |
| Back to top |
J. Schwiebert Guest
Posted: Wed Nov 21, 2012 4:25 pm Post subject: Re: 880 clutch |
You do no drain any oil! You pull thr long shaft, not the shaft you hook the implement too. |
| Back to top |
Posted: Wed Nov 21, 2012 7:00 pm Post subject: Re: 880 clutch |
thanks again for you info yes this aft. i finally figuired it out and got everthing apart. do you know if the pressure plate fingers can be set up for more movement or if it is just a new one needed? |
| Back to top |
J. Schwiebert Guest
Posted: Thu Nov 22, 2012 4:29 am Post subject: Re: 880 clutch |
As the clutch wears the levers move back. So the clutch releases sooner. Also the clutch disk is thinner because of wear. Since your clutch did not release, I would say the pilot bearing has failed causing the shaft to keep rotating. I also was not too clear on your comment about problems shifting from one range to the other range. Does the transmission imput shaft have any endplay? If so repair it while the engine is out. |
| Back to top |
Posted: Thu Nov 22, 2012 12:15 pm Post subject: Re: 880 clutch |
well its all apart now. actually the pilot bearing was good, but for $7 will get a new one. there is still some flywheel side paint markings on the clutch, it seems quite good. lots of wear on the pressure plate fingers. definately needs a new pressure plate and will also get a new throught bearing. i did not chech tranny input shaft end play. thanks for all the help. |
| Back to top |
