Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1957 Ford 600 carb bowl drain plug
Post new topic    Yesterday's Tractors Forum Index -> Restoration and Repair Tips
BillRemski
PostPosted: Wed Nov 21, 2012 12:21 pm    Post subject: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
The carb bowl drain plug on our Ford 600 started dripping gas. I have the shop manual but there is no part number listed for this and Steiner and Tractor supply only sell the part in a $60 kit. Does anyone know the specs on this part? If it is a standard size I can get it from a hardware supplier, but I can"t really get the specs from the plug that"s in there because it is just a cutoff machine screw from the looks of it and doesn"t have the conical seat at the end where it seals with the carb bowl casting. Thanks.
rustyfarmall
PostPosted: Wed Nov 21, 2012 1:30 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
The drain plug is basically just a 1/8" pipe plug, available at most any hardware store, but from the way you describe it, maybe you're talking about something else?
BillRemski
PostPosted: Wed Nov 21, 2012 2:46 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
Thank's Rusty. This is a lot bigger than 1/8 inch. I found a picture of it online in a listing for a repair kit and it's a brass plug with a conical seat, about 3/8 inch diameter at the threads. The one that's in there now is just a plain plug and it's steel and it leaks. I'm going to check the repair kit manufacturer site, if I can find it and see if I can order just the plug.
rrlund
PostPosted: Wed Nov 21, 2012 3:07 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
A good hardware store will have that plug in brass. I'm not talking the hardware department at WalMart though.
BillRemski
PostPosted: Wed Nov 21, 2012 3:15 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
Thanks. After the holiday I will check the local S&H as they have a lot of hardware and fittings. I'll dig up the specs on it somewhere.
showcrop
PostPosted: Wed Nov 21, 2012 6:06 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
BillRemski wrote:
(quoted from post at 15:46:26 11/21/12) Thank's Rusty. This is a lot bigger than 1/8 inch. I found a picture of it online in a listing for a repair kit and it's a brass plug with a conical seat, about 3/8 inch diameter at the threads. The one that's in there now is just a plain plug and it's steel and it leaks. I'm going to check the repair kit manufacturer site, if I can find it and see if I can order just the plug.
A 1/8 pipe thread is about 3/8 diam. 1/2 inch is about 3/4, 3/4 is about one inch. Maybe somebody who is a plumber knows why.
gab
PostPosted: Wed Nov 21, 2012 6:33 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
Never had a ford carb apart, had an A/C and a half dozen Farmall carbs apart and they all have an 1/8 inch pipe plug for the bowl drain. If you have a decent tap and dye set it should have a 1/8 " pipe tap in it witch is about 3/8" in diameter to compare to what's in your carb.
BillRemski
PostPosted: Wed Nov 21, 2012 7:21 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
Thanks for the information. I don't know all the plumbing parts, but if this is a standard item I should be able to find it at the local hardware. Seems like a common item to lose considering how many times I had the one out of the old 8N.
BillRemski
PostPosted: Wed Nov 21, 2012 7:24 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
I'll have to ask the neighbor, who's a plumber, why they are called what they are next time I talk to him. If it's a standard part I can see why the tractor part shops don't sell it.
Chavey
PostPosted: Wed Nov 21, 2012 8:14 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
re:pipe thread. pipes are measured on inside dia.for obvious reasons. so the outside thread has to be larger to allow for the pipe wall.
consequntially, a 1/2" pipe, schedule 40,will have an outside diameter of approx.3/4"
And so on for other sizes.
souNdguy
PostPosted: Sat Nov 24, 2012 5:39 pm    Post subject: Re: 1957 Ford 600 carb bowl drain plug Reply to specific post Reply with quote
yep.. 50 cent 1/8 pipe plug..
