Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Case 680H wiring issue
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
banks0531
PostPosted: Wed Nov 21, 2012 2:26 pm    Post subject: Case 680H wiring issue Reply to specific post Reply with quote
I recently traded my bobcat 610 for a case 680H backhoe in really good shape. The key switch is bad and someone disconnected the switch and all gauges, you start it with a push button. The main problem I see and want to fix is that the starter looks to be replaced not too long ago, on top of the starter is the solenoid, it has some part numbers and says 12volts, but the batteries are wired to be 24volts. I would like to know what I can do to fix this, or is this something that is ok? Also, how can I be able to wire back all the lights and gauges to be 12v? Thanks.
banks0531
PostPosted: Wed Nov 21, 2012 2:34 pm    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
Also, can I rewire the batteries to be 12volts instead of 24volts and will 12v be enough to turn over the motor?
JGarner
PostPosted: Wed Nov 21, 2012 8:38 pm    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
I think the 680 is basicallly drive train wise an 830. Our 830 had two batteries hooked together but I never paid any attention to see if the were hooked in series, (24V) or parallel, 12V. I think they were wired parallel and it turned over very good as you had increased amps hours to give it the kick.
Jim
EricB
PostPosted: Wed Nov 21, 2012 11:23 pm    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
I also have a 680H backhoe and the whole machine operates on 24 Volt. I suggest you try to keep everything original if you can. You would not have enough amps to the starter if you feed it 12 volts although if you really want to change it to 12 volts you can probably get such a starter if you check around. The downside with 24 volt is the cost of bulbs etc. I've had mine for 14 years and it's been a very good unit with little downtime. It's a bit thirsty on fuel but it will do a lot of work too.
Case Nutty 1660
PostPosted: Thu Nov 22, 2012 12:10 am    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
680H has a 336 (870) engine and industrials were 24 volt like stated above, the "W" series loaders were all 24 volt as well much better cold weather starting cnt
banks0531
PostPosted: Thu Nov 22, 2012 6:08 am    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
I will leave it 24v, but the starter says 12v on top of the solenoid. Will this be a problem using 24v for a few seconds to start the loader? Can I wire a 12v system from the batteries so I can have a radio and normal lights?
banks0531
PostPosted: Thu Nov 22, 2012 7:03 am    Post subject: Re: Case 680H wiring issue Reply to specific post Reply with quote
Another issues I'm having with it, is when I got it, it ran good, but as soon as I put 5gal of diesel in it, it wanted to start running rough and wanting to die out. I knew the previous owner of the backhoe, and when he put fuel in it, it did the same thing. He changed fuel filters and it never did it again.
