| Author |
Message |
mlshvb Regular
Posted: Wed Nov 21, 2012 6:17 pm Post subject: WHITE 160 good and bad |
I see that there is a 160 MFWD on an upcoming auction. Anyone have one or familiar with one to give a guy some pointers on what too look or watch for? |
| Back to top |
oliver fan Long Time User
Posted: Thu Nov 22, 2012 7:38 am Post subject: Re: WHITE 160 good and bad |
My brother has one and he really likes it. The Cummins engine and the good fuel economy are strong selling points. I don't think he has had any problems with it. |
| Back to top |
B A Star Long Time User
Posted: Thu Nov 22, 2012 7:48 am Post subject: Re: WHITE 160 good and bad |
I have a good friend that had a 160 and his brother-in-law has two of them. The guys are very good at maintenance and have not had any problems, all tractors north of 8000 hrs.
Charles City transmission and final drive, Cummins 8.3L engine and ZF front axle. All good componenets. One got traded for a new tractor and was gone from the dealers used lot in two days. |
| Back to top |
Joel IA Guest
Posted: Thu Nov 22, 2012 9:11 am Post subject: Re: WHITE 160 good and bad |
Very Good tractor mechanically and in the field. Cons - Does not turn short, and hauling loads down the road with a short wheel base it hopped or bobbed. Otherwise very good tractor, we had one for several years - it was nick named "Bob". |
| Back to top |
Close by Guest
Posted: Thu Nov 22, 2012 8:27 pm Post subject: Re: WHITE 160 good and bad |
Careful what you buy there he didn't have a good reputation probably see you there |
| Back to top |
jordan hackman Regular
Posted: Thu Nov 22, 2012 10:44 pm Post subject: Re: WHITE 160 good and bad |
my grandpa has one and my uncle mainly uses it. he doesn't use it as much anymore but it one of the best tractors in the family. good power, can't beat a cummins. the only problems with the tractor is that like all other FWA tractors it has a narrow base and can only make wide turns. |
| Back to top |
eeairshows New User
Joined: 08 Dec 2012 Posts: 7 Location: Oskaloosa, Iowa
Posted: Sat Dec 08, 2012 8:49 am Post subject: Re: WHITE 160 good and bad |
I have a 2-180 FWA re-engined with the 8.3 Cummins. It is a Tourque Monster and I really like the over under feature. Turn raduis is = to or better than my 2wd JD 4440
Th bads are that it is almost impossible to shift from one gear to another on the fly which makes it a pain to haul in with. However, it's worst problem is that it is a rough riding SOB, which is a function of it's short wheel base. An air ride seat helped, but not enough. I am trying to find a front end loader to put on mine and retire it from field use because of the rough ride. I have back problems. If you don't the 160 is probably a great tractor for you. |
| Back to top |
eeairshows New User
Posted: Sat Dec 08, 2012 9:08 am Post subject: Re: WHITE 160 good and bad |
I forgot to say that the other White weakness I am aware of is that the radiator fan shroud on both my 2-105 & 2-180 were jokes as there is no horizontal surface area near the fan so the "shroud" basically isn't one and on hot days they are prone to overheating.
I have just put up with it on my 2-105. On the 2-180 I retrofitted a shroud off an old JD7520. That, along with removing the stock headlights for extra air intake area and putting on a more efficient fan completely cured it and I have pulled it hard on a 100+ degree day without it ever overheating. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
