| Author |
Message |
mike paulson Long Time User
Posted: Thu Nov 22, 2012 2:21 am Post subject: MF 50 runnin alittle rough.. |
I have noticed after i let my MF 50 sit for a week in the cold and then go to run her it will spit and sputter some, and wont stop even when warmed. i do some readjusting on the carb and drive it around and after a while things seem to smoth out. if i start it later in the day all is fine and dandy. but 2 weeks later i go to start it and the same thing happens.
I have a completely rewired this tractor, it has a fresh tune up including all components, plugs, wires, cap rotor, points condensor, etc, just to get that out the way.
I rebuilt my carb last weekend and my feul supply seems good, with good gas. When she sputters i pull the choke closed slightly to enrich and she sputters worse showing me its not lack of fuel...any ideas, maybe a weak coil? |
| Back to top |
miner09 Long Time User
Posted: Thu Nov 22, 2012 5:38 am Post subject: Re: MF 50 runnin alittle rough.. |
Most of the time a coil run's OK when cold. Sound's like maybe moisture in cap. |
| Back to top |
2tractors Long Time User
Posted: Thu Nov 22, 2012 6:23 am Post subject: Re: MF 50 runnin alittle rough.. |
Maybe pull the plugs after 2 weeks and after trying to run and check for oil leaking from head.May need a valve job. Check compression too. |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9866 Location: Western Montana
Posted: Thu Nov 22, 2012 7:01 pm Post subject: Re: MF 50 runnin alittle rough.. |
Check the spark. Should be FAT AND BLUISH-WHITE, the color of lightning. |
| Back to top |
Posted: Fri Nov 23, 2012 1:59 am Post subject: Re: MF 50 runnin alittle rough.. |
yea my plugs look fine only alittle carbon and my cap is bone dry, its stored indoors in an outbuilding. Im gonna check spark and ohm out the coil... |
| Back to top |
D.T Guest
Posted: Sat Nov 24, 2012 5:16 am Post subject: Re: MF 50 runnin alittle rough.. |
If you have changed all your electrical coponents and your sure everything is right there better pick on the carburator, play with your fuel mixture screw or make sure it is sealed right on manifold as well |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
