| Author |
Message |
Bspauld Long Time User
Posted: Thu Nov 22, 2012 6:03 am Post subject: JD 420 |
I have a 420 that freewheels. When going down a hill I have to pull the speed control way back and when i get to the bottom it stops, I have to push the lever forward . I am going to change the transmission oil filter, Any ideas on what can be done about it? Thanks for any that respond |
| Back to top |
chevy65 Regular
Posted: Sun Nov 25, 2012 4:17 pm Post subject: Re: JD 420 |
Ur problem is simple Depending on age of tractor the hydro linkages vary Problem is u have excessive play in the linkage Most likly spot is the arm that hooks to the transmission The arm is attached to the trans by a roll pin it is probably broken or the arm is sloppy on the shaft other sloppy areas in linkage will cause problems too |
| Back to top |
Posted: Mon Nov 26, 2012 6:59 am Post subject: Re: JD 420 |
Thank you for the advice. I will check that out. |
| Back to top |
chevy65 Regular
Posted: Mon Nov 26, 2012 3:53 pm Post subject: Re: JD 420 |
let me know what u find Good luck |
| Back to top |
Posted: Tue Nov 27, 2012 1:22 pm Post subject: Re: JD 420 |
pretty cold out in the shop right now, but i will let you know when I do look at it. Thanks again |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
