Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
lubing pivot fittings on kingpins on Farmall 300
Post new topic    Yesterday's Tractors Forum Index -> Restoration and Repair Tips
Ed Brewer
PostPosted: Fri Nov 23, 2012 7:50 am    Post subject: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
Unable to grease wide front end fittings on 55 -57 300 farmall new grease fittings won,t accept grease. have tried 2 grease guns and several fittings
Any suggestions would be welcomed.
Motorcraftman
PostPosted: Fri Nov 23, 2012 11:36 am    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
I have found that also, I have a 16 Disc harrow that has the "China Junk" Fittings in it, They WONT take grease either, Buy USA Made Fittings, problem solved.. Larry KF4LKU
NCWayne
PostPosted: Fri Nov 23, 2012 10:28 pm    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
First be sure the grease fitting themselves are good, and many nowdays are not. If they are good then penetrating oil can often help. If you can get a pipe fitting in the grease fitting hole in such a manner that you can fill it with penetrating oil, and then install the grease fitting, that's the best thing to do. Once you have the fitting in, everything full of penetrating oil, and the grease fitting in place also, put your grease gun on it and give it a pump or so to make it build pressure. If your lucky, and it tends to work for me about 75% of the time (especially if you give the penetrating oil time to soak in good, and free up the blockage) you'll get a good bit of pressure built and then you'll feel a pop as the joint starts taking grease. That's about the easiest way I've found to get an joint that isn't taking grease to start taking it again. Usually the next alternative is to disassemble the joint and go from there.
JMS./MN
PostPosted: Sat Nov 24, 2012 12:02 am    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
Problem is old crusty grease in the joint. Take a small drill bit, spin it in the hole by hand, working thu the old grease. shoot some good penetrant in....that is not WD40 squaw urine..........use PB Blaster, etc. Stick the zerk on the gun, shoot some grease so you know the zerk is good, then install and pump grease.
willie in mn
PostPosted: Sat Nov 24, 2012 12:56 am    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
All good hints below. Have a couple more.
Jack it up so the wheel hangs free. This changes the load pressure to a different point. Gaining .001 clearance might be just enough to get grease started. Helps a lot on ball joints/kingpins on cars/trucks.
If not real concerned about hurting the paint, GENTLE application around the zerk with the blue flame tool often softens the old grease.
Different things work at different times. One or more of the methods others have listed should work.
Willie
rrlund
PostPosted: Sat Nov 24, 2012 10:44 am    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
Heat. I had to heat some loader pins a week ago to get the old crud loosened up so they'd take. I would seriously warn against heating a zerk though. Take it out before you apply the heat. There's a little BB in the end of them and if you build pressure in them heating them,that little thing will shoot out of there like a tiny bullet.
Ed Brewer
PostPosted: Sat Dec 01, 2012 4:34 pm    Post subject: Re: lubing pivot fittings on kingpins on Farmall 300 Reply to specific post Reply with quote
THANKS for the responces. I was able to free up four fittings on the assembly,using penitrating oil and the pipe filled with penitrating oil and shooting it with grease gun.
E.B.
