| Author |
Message |
Plow24 Regular
Posted: Fri Nov 23, 2012 3:20 pm Post subject: Allis B Pieces In Oil Pan? |
Well I just bought a 47 Allis B Tractor. I was told the engine was stuck and boy oh boy is it stuck. I have tried ATF And Diesel and still nothing yet. I pulled the head and now just removed the oil pan. I found these pieces inside the oil pan, What are they????
I also noticed inside the starter housing where the oil tube comes out right behind the starter housing there is a couple pieces of cast missing. I think I found those also in the oil pan ( not pictured ).
Is this motor junk? I am just not sure if this thing is worth dumping the money into it.
Thanks for the help!
| Back to top |
Lonnie Smith Regular
Posted: Fri Nov 23, 2012 4:49 pm Post subject: Re: Allis B Pieces In Oil Pan? |
Hard to tell the size of the parts but it looks like governor pieces. If they are it might have more pieces in the front of the motor that are locking it up? |
| Back to top |
Dick L Tractor Guru
Posted: Sat Nov 24, 2012 7:25 am Post subject: Re: Allis B Pieces In Oil Pan? |
One mans junk is another mans treasure. (:^D
You might want to strip it down to the bare block, spec check all the parts and see where you need to go from there. That will not cost you big bucks and you will learn a lot about your engine that you would never learn any other way. If it is locked up from a shattered governor you will find that behind the front cover. That is what the pins look like they came from to me also. Might only take a governor assembly and a camshaft gear if it didn't get full of water. |
| Back to top |
Plow24 Regular
Posted: Sat Nov 24, 2012 10:31 am Post subject: Re: Allis B Pieces In Oil Pan? |
A locked up governor could cause the engine not to turn?
I took that back cap off the governor area and all seems to be fine, is this something I have to take apart to see if there are pieces missing? |
| Back to top |
Aaron SEIA Long Time User
Posted: Sat Nov 24, 2012 12:55 pm Post subject: Re: Allis B Pieces In Oil Pan? |
If the pieces fell off the gov and worked their way down into the gear train, they could have. The gov is driven off of the camshaft and the cam off of the crank. Any loose parts in between will cause problems. I agree with the others, sounds like it needs to have the front cover removed and the gov taken off to see where the pieces came from. If the weights came off the gov, it could have ran reeeeeeeaaaaaaal fast and locked up as well.
AaronSEIA |
| Back to top |
Plow24 Regular
Posted: Sat Nov 24, 2012 6:21 pm Post subject: Re: Allis B Pieces In Oil Pan? |
Take the front cover off............. what front cover?
The front cover of the engine? or the backside of the magneto area?
Thanks |
| Back to top |
Posted: Sat Nov 24, 2012 6:31 pm Post subject: Re: Allis B Pieces In Oil Pan? |
Yes, the flat plate on the front of the engine and the governor housing. |
| Back to top |
Posted: Sat Nov 24, 2012 7:18 pm Post subject: Re: Allis B Pieces In Oil Pan? |
Sounds like you also need to get an I&T or Allis shop manual so you know what to take apart and how it goes back together. Here is a link to the AGCO on-line parts book for the B. Should be able to find exploded views of the engine and gov setup that'll help you out as well.
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001543
AaronSEIA |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
