Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1555 hesitation carburetor
Post new topic    Yesterday's Tractors Forum Index -> Oliver, Cletrac, Coop and Cockshutt
Bob seND
PostPosted: Fri Nov 23, 2012 6:58 pm    Post subject: 1555 hesitation carburetor Reply to specific post Reply with quote
I've replaced the carburetor with a rebuilt one. It fixed the need to run with choke on, but I can't get it adjusted to eliminate the stumble/hesitation on opening the throttle. I've adjusted the load and idle screws per specs, and per multiple recommendations on this forum. Is that as good as it gets?
rpostmo
bobbyboywestcentIN
PostPosted: Fri Nov 23, 2012 11:15 pm    Post subject: Re: 1555 hesitation carburetor Reply to specific post Reply with quote
try looking on the ignition side then. maybe new plugs.
johns
PostPosted: Sat Nov 24, 2012 5:14 am    Post subject: Re: 1555 hesitation carburetor Reply to specific post Reply with quote
Bob, when I worked at our local dealer the tractors that came in with an aluminum bodied carb we would swap out for the same one except with a cast iron body. The aluminum ones would warp and we could never get them to run right. Not sure what model the 155 has or if this would fix your problem, but it sounds like you"ve tried a number of things.
young tractor
PostPosted: Sat Nov 24, 2012 6:25 am    Post subject: Re: 1555 hesitation carburetor Reply to specific post Reply with quote
I darned near lost my religion over a 1850 gas that was like that. I ended up finding some insulation in the top neck of the sediment bulb. It just wasn't getting quite enough fuel. I did everything I could think of. I rebuild the carb, electrical, etc. The final touch to get it running just right was to farmer time it by sound. Just loosen the distributor a little with it running and move it a little one way or the other until it was running just right. Now it roars right out of the yard and has been for 7 years since.
rrlund
PostPosted: Sat Nov 24, 2012 10:37 am    Post subject: Re: 1555 hesitation carburetor Reply to specific post Reply with quote
Are your points opening far enough?
If it's just a hesitation when you take off,I'd rule out any problem with gas flow to the carb. The carb bowl should hold enough gas to run the tractor for 10-15 seconds anyway.
