| Author |
Message |
Jr. Roby Regular
Posted: Sat Nov 24, 2012 10:16 am Post subject: oil pressure |
what is a normal oil pressure for these old fergies? |
| Back to top |
miner09 Long Time User
Posted: Sat Nov 24, 2012 10:36 am Post subject: Re: oil pressure |
Around 20--25 |
| Back to top |
John(UK) Long Time User
Posted: Sun Nov 25, 2012 5:51 am Post subject: Re: oil pressure |
Depends on what engine you have, A Continental Z120 or Z129 should be 20-30psi at full throttle and 15psi at idling speed when the engine is in good order and has the correct grade of oil. If it is a Standard Motors Engine it should be between 40-60psi at full throttle and around 20-30 at idle. Often low oil pressure is because the Oil Pump is worn and it is something that is often forgotten about, it could also be that the pressure relief valve on the Pump is sticking and needs cleaning, but more often the Pump will be worn..John(UK)....fergusontractors@hotmail.com |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9850 Location: Western Montana
Posted: Sun Nov 25, 2012 1:19 pm Post subject: Re: oil pressure |
The book says 25-30 psi on an engine at operating temperature with a min acceptable of 15 psi at 400 rpm. Our TO-30, hot or cold, at any rpm is a consistant 27 psi. Never varied in 11 years. Only time it goes lower is when I shut it off. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
