| Author |
Message |
steamnjn23 Regular
Posted: Sat Nov 24, 2012 9:03 pm Post subject: What am i looking at? |
Hey guys,
I am considering rescueing an old massey. How can I tell exactly what I am looking at? I do know it has a diesel engine...and it did "run when parked". ( dont they all say that) Beyond that I am clueless. I need advice.
Where do i look?
What am i looking for?
Is there anything I should run from? |
| Back to top |
Inno Tractor Expert
Joined: 11 Nov 2009 Posts: 1861 Location: NW Ontario Canada, Near Beautiful Rainy Lake
Posted: Sun Nov 25, 2012 5:44 am Post subject: Re: What am i looking at? |
Look for a model/serial number plate. Without more clues though I can't really tell you much more. Many models had a number plate on the left side of the dash/inst. panel. Failing that look around the engine for clues, often there will be a plate on the engine which is a good place to start..........often they are covered in oil/grease.
If you could post a picture that would be the best way to start. As far as things to run away from, I don't think I've heard of too many that are absolute junk. While certain machines are prone to certain problems, what should be bought vs. what shouldn't is often dictated by your level of mechanical skill and pocket book.
| Back to top |
Phil Tibbetts Long Time User
Joined: 23 Jul 2004 Posts: 770 Location: Old Town, Maine
Posted: Sun Nov 25, 2012 6:24 am Post subject: Re: What am i looking at? |
Well to start with if it is a 35 or 135 make sure it has the Perkins diesel engine. Some early 35's had the Standard diesel. I would stay away from that engine. Perkins is 3 cylinder, Standard is 4 cylinder. IMHO |
| Back to top |
BIG RUH Regular
Posted: Sun Nov 25, 2012 8:46 am Post subject: Re: What am i looking at? |
Old Massey Harris or Massey Ferguson?????????????? |
| Back to top |
steamnjn23 Regular
Posted: Sun Nov 25, 2012 9:37 am Post subject: Re: What am i looking at? |
Sorry Big, this is a Massey Ferguson.
Its at least a 1958 model or newer. The owner said it has sat for 20 years. I did notice that he had the intake pipe covered with a metal cap...that could be a good sign. I remember seeing some hydrolic hoses on the frame in front of the radiator.
I'm going to look at it today with a camera, and i"ll report back later. I'm looking for this tractor to be a winter project. |
| Back to top |
samn40 Tractor Expert
Posted: Sun Nov 25, 2012 11:34 am Post subject: Re: What am i looking at? |
On a continental gas engine, look for milky engine oil, and then
slowly walk away and see if you can find a decent block .... milky
rear end oil is normal and usually only requires a washout and
new oil and rubber gaiters around the gear levers. Look to see if
it has Multi-power, there will be a rod going down into the
gearbox from under the battery tray like the one with the little
bellows affair in my picture. If the tractor will not start and you
cannot check the multi operation(semi automatic overdrive on
every gear) remember to assume it is not working when you are
making your deal as it can get spendy!
Sam
| Back to top |
steamnjn23 Regular
Posted: Sun Nov 25, 2012 1:32 pm Post subject: Re: What am i looking at? |
here are a few photos of the tractor. I am assuming it doesnt run. The owner and i are talking about a non-running tractor
| Back to top |
Inno Tractor Expert
Posted: Sun Nov 25, 2012 1:43 pm Post subject: Re: What am i looking at? |
Looks like a 1959 Massey Ferguson 65. A good tractor. I'm not familiar with diesel engines but according to TractorData the 65 came with either a Continental gas engine or the Perkins 4cyl. diesel engine. If it is the Perkins then it is also a well liked engine.
Whether it's worth buying depends on the price, options and what it needs as well as your level of expertise.
Edit: looks like it might have multi-power, that can be expensive and complicated to work on. Looks like a project!
| Back to top |
steamnjn23 Regular
Posted: Sun Nov 25, 2012 2:02 pm Post subject: Re: What am i looking at? |
Inno, currently he is asking scrap price for it. I guess thats fair. |
| Back to top |
mike paulson Long Time User
Posted: Sun Nov 25, 2012 3:16 pm Post subject: Re: What am i looking at? |
i love the axle on the front bumper. |
| Back to top |
Posted: Sun Nov 25, 2012 4:41 pm Post subject: Re: What am i looking at? |
Well it is one of the best tractors ever built! A Massey Ferguson 65
with the Perkins diesel engine. It definately should be worth
restoring, good news is all parts are available and plentiful.The two
in my photos are gas tractors but will give you some ideas.
Good luck with it if you purchase!
Sam
| Back to top |
Steven-Id Regular
Posted: Sun Nov 25, 2012 9:16 pm Post subject: Re: What am i looking at? |
the serial # says it is a 1959 MF65.It is SNM 669??? says it is a utility with a diesel and a 2 stage clutch. I don't know about the multipower however.
Steven |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Mon Nov 26, 2012 7:09 am Post subject: Re: What am i looking at? |
Ya know Sam, I hate to agrue with you about anything but beer, but I wouldn't worry about a -what are in these in non diesel? 176 Cont's? But I have a gas 65 with a multipower...and in nearly 2 years...I have yet to tamper with it. Whatever position that lever was in, it hasn't moved... just out of fear of the unknown...
All in all, Steam better just pay the man and sort it out when it gets home. |
| Back to top |
Dave+Id Guest
Posted: Mon Nov 26, 2012 11:19 am Post subject: Re: What am i looking at? |
I'd take it in a heart-beat. The 65 diesel I had was perfect except I needed a loader, so I traded it in for a new Massey.... shoulda, coulda, kept it. |
| Back to top |
Our Farmer Guest
Posted: Tue Nov 27, 2012 6:58 am Post subject: Re: What am i looking at? |
Grab it with both hands.
I have a 58 (British), which I bought in not much better shape than that. Rebuilt the motor, hydraulics,replaced the clutch and all the wheel bearings. Best tractor ever built IMHO. Mine looks not quite as good as the restored model, but she works most days,so she's got an excuse.
That one's US, so parts are plentiful without the quirks mine has. MF dealers are pretty proud of what parts they sell, so you're better off to get what you can direct from Perky, and wheel bearings and such from a parts jobber. |
| Back to top |
