| Author |
Message |
boler76 Regular
Posted: Sun Nov 25, 2012 7:05 am Post subject: front mount dist timing revisited |
Would it be common to have to file the timing slot to be able to get the 1/4" measurement? To get the right timing the concave screw is now off centre of the hole, not touching but not leaving much room for the tapered spring? Maybe I have overlooked something? bearings seem OK as no visible slop ???? Thanks |
| Back to top |
HCooke Tractor Expert
Posted: Sun Nov 25, 2012 7:57 am Post subject: Re: front mount dist timing revisited |
Brass screw should be pretty well centered when the timing is correct. Sure you have the straight edge on the correct side of the tang?? |
| Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 11313 Location: Old Church VA
Posted: Sun Nov 25, 2012 7:58 am Post subject: Re: front mount dist timing revisited |
" Would it be common to have to file the timing slot to be able to get the 1/4" measurement? "
No.
Make sure you have the locking C clamp positioned correctly, as in the picture.
Were you able to easily tell the wide side of the tang from the narrow side?
Did you set the points gap before you set the timing?
75 Tips
| Back to top |
Bruce(VA) Regular
Posted: Sun Nov 25, 2012 7:59 am Post subject: Re: front mount dist timing revisited |
Brilliant minds think alike.......  |
| Back to top |
boler76 Regular
Posted: Sun Nov 25, 2012 4:20 pm Post subject: Re: front mount dist timing revisited |
set points at .015 before setting timing, got new points because thought maybe the old ones were worn too much, no difference and the wide side of the engaging tang is readily noticeable, have the "C" shaped circlip installed as shown ??? |
| Back to top |
JMOR Tractor Guru
Posted: Sun Nov 25, 2012 6:11 pm Post subject: Re: front mount dist timing revisited |
| boler76 wrote: | | (quoted from post at 20:20:36 11/25/12) set points at .015 before setting timing, got new points because thought maybe the old ones were worn too much, no difference and the wide side of the engaging tang is readily noticeable, have the "C" shaped circlip installed as shown ??? | It is imperative that you set it by rotating in correct direction. Turn in wrong direction & you can not get the desired setting.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
