830 brakes
830 man
PostPosted: Sun Nov 25, 2012 3:07 pm    Post subject: 830 brakes Reply to specific post Reply with quote
Hello all. In early spring i puchased a 62 model 830 for $1200. It had a good running diesel engine, but virtually no brakes.
After pulling the brake covers i found everything covered in grease and rust. The shafts themselves were severely worn. Now i have new disc, seals, and the shafts are at the machine shop. My question is how do i determine which balls i should use?
John Saeli
PostPosted: Sun Nov 25, 2012 5:01 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
5/8" Dia Balls. Why are the shafts @ the machine shop? A simple repair sleeve was all that was needed.
830 man
PostPosted: Sun Nov 25, 2012 5:24 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
The splines were terribly worn. Do the make a sleeve to fix the splines? I was going to buy more shafts, but money wouldn't allow. I also have new dust covers. I need to order springs & balls.
John Saeli
PostPosted: Sun Nov 25, 2012 7:20 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
I don't know of any way to repair the splines. Did the shop say how they do that? The repair sleeves are for the smooth surface where the seal rides. e-mail is open.
830 man
PostPosted: Sun Nov 25, 2012 7:39 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
The machine shop said they can weld them up and machine new splines. I have my fingers crossed.
casecollectorsc
PostPosted: Sun Nov 25, 2012 8:08 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
They must really be worn. I have seen some bad ones, but smooth them up so discs don't hang up and redi sleeves where the seals go and your ready to go. Doubt you'll ever wear them all the way thru.
mopar6701
PostPosted: Mon Nov 26, 2012 10:41 am    Post subject: Re: 830 brakes Reply to specific post Reply with quote
on my 730 i had one that wore the splines so bad that the disc was spinning on the shaft. i cleaned it all up and bought a new disc. the new disc had better splines in it and held on the shaft but once it wears im pretty sure its going to spin someday too since the shaft is so badly worn
830 man
PostPosted: Mon Nov 26, 2012 12:27 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
Thats what im afraid would happen to mine down the road if i didnt have the shafts machined now.
830 man
PostPosted: Mon Nov 26, 2012 12:31 pm    Post subject: Re: 830 brakes Reply to specific post Reply with quote
Once im done with the 830 i get to tear into my 430 diesel brakes. I think it just needs seals and disc though.
