| Author |
Message |
Dodgeit Long Time User
Posted: Sun Nov 25, 2012 4:34 pm Post subject: Need to get to speedo gear Help |
Have the trans cover off and both bolts removed from the casting holding the speedo gear, but can't get the casting to come off. The other problem is that the worm gear that drives the speedo gear, turns freely. Since this is hooked to the Pinion shaft should it be able to freewheel?
The speedo doesn't work, but the gauge on the cluster is fine, as is the speedo cable. So it's the speedo drive gear or the gear on the pinion shaft.
Thanks for the help |
| Back to top |
Jeff B. Regular
Joined: 11 Oct 2008 Posts: 414 Location: Idaho Falls, Id.
Posted: Mon Nov 26, 2012 7:47 pm Post subject: Re: Need to get to speedo gear Help |
The way to refer to those gears are the drive and driven gears. The drive gear spins the driven gear, which in turn spins the cable. The drive gear should definitely be fixed to the shaft. I can't offer a fix, as I don't know the exact setup.
I hope this helps a little. |
| Back to top |
Posted: Wed Nov 28, 2012 4:08 am Post subject: Re: Need to get to speedo gear Help |
| Jeff B. wrote: | (quoted from post at 22:47:59 11/26/12) The way to refer to those gears are the drive and driven gears. The drive gear spins the driven gear, which in turn spins the cable. The drive gear should definitely be fixed to the shaft. I can't offer a fix, as I don't know the exact setup.
Thanks for the clarification. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
