Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Someone set me straight.
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> John Deere
NEKS
PostPosted: Sun Nov 25, 2012 6:22 pm    Post subject: Someone set me straight. Reply to specific post Reply with quote
Just heard today that all B JD's did not have petcocks on the cylinders. A's and G's did. Grandpa had a early styled B and it had petcocks you closed after starting. If B's had them they were installed later. Set me straight. Thanks
BushogPapa
PostPosted: Sun Nov 25, 2012 6:27 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
Maybe not "All" of them did, but I bet "Most" of them did..
Would have been stupid not too...!!
Can hardy believe, the 60/630's didn't have them from the factory..
Ron..
David G
PostPosted: Sun Nov 25, 2012 6:33 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
I had a 51 that had them.
teddy52food
PostPosted: Sun Nov 25, 2012 6:36 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
My 1935 does not have them.
CLW
PostPosted: Sun Nov 25, 2012 6:51 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
If I remember right they may have done away with them on the very late models. If they did there would be a plug where it would have been. You could remove the plug and install one if needed. My 52 A had them on the bottom of the engine. I don't remember the 1950 model B I grew up with having them but never looked under it. One thing not many are aware of is the B had a conversion kit that allowed for 2 Batteries under the seat.
F-I-T
PostPosted: Sun Nov 25, 2012 6:59 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
FSB 178, April 1951 said that compression relief cocks were no longer being supllied on A,B,G tractors as they not of general use, and as an effort to conserve copper (Korean War), but they could be ordered as replacement parts if required, so pipe plugs were installed into the machined ports. I THINK that early "B"s did not have them added into the block until l ater, but there is mention of an improved design being introduced in '39. A different angle attempted to blow the fuel and oil away from the tractor.
Paul from MI
PostPosted: Sun Nov 25, 2012 7:45 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
Unstyled B's did not originally have petcocks. There is a flat spot on the side of the cylinder that may have been drilled & tapped later to add them. My '37 B with original low compression pistons cranks very easily with out them. Not so on my '44 B with gas pistons, it needs the petcocks.
Kurt_JDB
PostPosted: Sun Nov 25, 2012 8:59 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
My 1937 and 1938 unstyled B tractors do not have them, and the block is not drilled and tapped for them either. My 1951 B does have them, but I hardly ever need them.
Kurt
gtx1967jewison
PostPosted: Sun Nov 25, 2012 9:38 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
My 48 B has them underneath. Owned it for years before i
cleaned off the gunk & found them Wink
jturbo10
PostPosted: Sun Nov 25, 2012 10:22 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
Our 39 styled B had petcocks.
jturbo10
davediehl@hotmail.com
PostPosted: Sun Nov 25, 2012 11:40 pm    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
My 51 does not have them.
James Howell
PostPosted: Mon Nov 26, 2012 2:41 am    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
Our 39 and 40 Model B have them on the side.
Our 43 Model B has them on the bottom.
rickdeere
PostPosted: Mon Nov 26, 2012 4:37 am    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
There on the bottom of the block with plugs in the holes.
rickdeere
PostPosted: Mon Nov 26, 2012 4:40 am    Post subject: Re: Someone set me straight. Reply to specific post Reply with quote
look on the botoom of block and plugs should be in holes,now I never seen a power block with them.
Goto page 1, 2  Next
Page 1 of 2
