| Author |
Message |
B Woods Regular
Posted: Sun Nov 25, 2012 7:09 pm Post subject: 5020 leaking oil |
my question is i have a 5020 John Deere that is leaking hydraulic oil out of the bottom of the clutch housing. Most likely the seal between the input shaft and the pto drive shaft or the seal in the end of the quill. Do you think i need to split at the clutch housing and the engine or the transmission case and clutch housing ,to get too both of these seals. |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5984 Location: Somerset Ohio
Posted: Mon Nov 26, 2012 3:55 am Post subject: Re: 5020 leaking oil |
Yes..a split is needed, check the rear main seal & clutch while your in there... |
| Back to top |
B Woods Regular
Posted: Mon Nov 26, 2012 6:01 am Post subject: Re: 5020 leaking oil |
tim you are saying the clutch housing and engine split, will get me to the 2 seals on the input shaft correct |
| Back to top |
David G Tractor Guru
Posted: Mon Nov 26, 2012 7:10 am Post subject: Re: 5020 leaking oil |
Agree totally on checking rear main seal. I had dealer change clutch on my Ford, now rear main seal is leaking, so another split. |
| Back to top |
tim s Tractor Guru
Posted: Mon Nov 26, 2012 8:53 am Post subject: Re: 5020 leaking oil |
Yes splitting right behind the engine block, putting you into the clutch area. |
| Back to top |
tim s Tractor Guru
Posted: Mon Nov 26, 2012 8:55 am Post subject: Re: 5020 leaking oil |
I always figure a rear main seal in with a clutch job, along with the input shaft seal. |
| Back to top |
B Woods Regular
Posted: Mon Nov 26, 2012 2:48 pm Post subject: Re: 5020 leaking oil |
Thanks i have done a 6030 but not a 5020 |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
