| Author |
Message |
Yooper Farmall Regular
Posted: Mon Nov 26, 2012 6:30 am Post subject: What are your thoughts on battery tenders? |
I"ve got a Farmall H that"ll be stored inside for 5 months, its got a battery that is a year old. Wondering if it would be a good idea to put my trickle charging battery tender on it, or if they pose any fire hazards.
I don"t really want to pull the battery because this summer I installed a new battery box and getting the battery in there and all the cables in place was a challenge. |
| Back to top |
DoubleR Long Time User
Posted: Mon Nov 26, 2012 6:41 am Post subject: Re: What are your thoughts on battery tenders? |
My C batt is about 7-8 years old. I would throw a charger on it every now and then for a few hours in the winter. The tractor normally sets for 3-4 months in the winter. The last couple years I've put a tender on it and plug it in for a few days now and then. I have never had any problems with the batt. I have not taken the battery out since I put it in. |
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18506 Location: Southwest Iowa
Posted: Mon Nov 26, 2012 6:42 am Post subject: Re: What are your thoughts on battery tenders? |
| Yooper Farmall wrote: | (quoted from post at 07:30:27 11/26/12) I"ve got a Farmall H that"ll be stored inside for 5 months, its got a battery that is a year old. Wondering if it would be a good idea to put my trickle charging battery tender on it, or if they pose any fire hazards.
I've got two of those tenders. They are probably the greatest thing to come along since sliced bread. Mine are now going on their second year of use with no problems of any kind.
I really do need to get two more. |
| Back to top |
d beatty Guest
Posted: Mon Nov 26, 2012 6:45 am Post subject: Re: What are your thoughts on battery tenders? |
I have been useing a battery tender for about 6 years with no problems. I have them on my garden and farm tractors. Those so called one year batteries for garden tractors are now lasting over 5 years. |
| Back to top |
flambeauone Regular
Posted: Mon Nov 26, 2012 7:04 am Post subject: Re: What are your thoughts on battery tenders? |
Ive not had any problems with using them. I plan on putting them on my mower next the tractor has had one in use for about three years. |
| Back to top |
CNKS Tractor Guru
Posted: Mon Nov 26, 2012 7:50 am Post subject: Re: What are your thoughts on battery tenders? |
I have 6 of them and leave them on all the time. You might keep your eye on them because on one tractor one battery leaked some water out the top, I simply left the caps loose, currently closed with no further problems. They work fine and are well worth the $20-25. |
| Back to top |
Dude with a 300 Regular
Joined: 27 Sep 2012 Posts: 44 Location: Raid City, SD
Posted: Mon Nov 26, 2012 8:05 am Post subject: Re: What are your thoughts on battery tenders? |
I have several 6 and 12 volt and really like them. I put one on a deep cycle battery for a winch on my trailer which I use a couple times a year at most. The battery is six years old and is in perfect condition. Put it on and leave it on. The price of the Battery Tender is quickly offset by not having to buy a new battery every couple years.
Bruce |
| Back to top |
Jim Becker Tractor Expert
Posted: Mon Nov 26, 2012 8:51 am Post subject: Re: What are your thoughts on battery tenders? |
Schumacher makes a good one, available at WalMart for about $20. They work great and are reliable. The same unit works on both 6 and 12 volt systems. It appears they have just changed the unit as WM web site is currently showing 2 models with one out of stock. You can find some cheap ones at places like Harbor Freight. Avoid them. |
| Back to top |
Posted: Mon Nov 26, 2012 9:00 am Post subject: Re: What are your thoughts on battery tenders? |
| Jim Becker wrote: | | (quoted from post at 09:51:10 11/26/12) Schumacher makes a good one, available at WalMart for about $20. They work great and are reliable. The same unit works on both 6 and 12 volt systems. It appears they have just changed the unit as WM web site is currently showing 2 models with one out of stock. You can find some cheap ones at places like Harbor Freight. Avoid them. |
Schumaker is what I have. I was just now looking on Amazon and they have them listed for $20 and some odd cents. |
| Back to top |
mike1972chev Long Time User
Posted: Mon Nov 26, 2012 11:10 am Post subject: Re: What are your thoughts on battery tenders? |
They are a great idea for batteries that "sit around" alot and while in storage. I have one from Auto Meter and it works great. |
| Back to top |
mkirsch Tractor Guru
Posted: Mon Nov 26, 2012 12:06 pm Post subject: Re: What are your thoughts on battery tenders? |
Been using the Schumakers for years. So far so good.
Also the $5 Harbor Freight ones. |
| Back to top |
LenNH Regular
Posted: Mon Nov 26, 2012 12:13 pm Post subject: Re: What are your thoughts on battery tenders? |
I don't have a tender, but I do store a battery from my tractor from September through June. I keep it in my garage and put a regular charger on it about every two weeks. Can't freeze that way, and it seems to work just fine in the spring. Have been doing this for 3 years now with the same battery. The tender sounds like a good idea, though. |
| Back to top |
Tom Fleming Tractor Expert
Joined: 06 Jun 2007 Posts: 2038 Location: pennsylvania
Posted: Mon Nov 26, 2012 1:30 pm Post subject: Re: What are your thoughts on battery tenders? |
I have 4 of them. Use them all the time. I reccomend them. Period. |
| Back to top |
Roger46 Regular
Posted: Mon Nov 26, 2012 5:22 pm Post subject: Re: What are your thoughts on battery tenders? |
I have been using BatteryMINDer brand battery tenders for many years. They are a little more expensive, but one of the guys I used to work with researched all the brands and found that that brand was the best for both maintaining the charge and conditioning the battery. I have batteries over 10 years old on one or two of my tractors using them. I have 8 of them that I just put on all my tractors and pickup put away for the winter. I will take them off in the spring when I start driving them.
Roger |
| Back to top |
BOB HAWBECKER Regular
Posted: Mon Nov 26, 2012 7:23 pm Post subject: Re: What are your thoughts on battery tenders? |
i have had good luck with Deltran Battery Tender
use it for riding mower & motorcycle & farmall & the ford tractor works great |
| Back to top |
