630 hyd lines
bigboreG
PostPosted: Mon Nov 26, 2012 8:38 am    Post subject: 630 hyd lines Reply to specific post Reply with quote
Working on a friends 630 and the hyd lines that run across the platform and feed the remote couplers rusted and are leaking bad. Can get new from deere but cost $240 EACH. So my question is, is it possible to make new ones from hyd hose, even though the orig are steel? He dont want to spend that much for new lines, and I cant find used. How hard would this be to do and would I need to somehow use the ends of old lines that connect to that valve body on right side?
M-MAN
PostPosted: Mon Nov 26, 2012 8:57 am    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
The steel tubing is pretty cheap at mcmaster carr but you would need a bender in that size.
ssgshelton
PostPosted: Mon Nov 26, 2012 10:30 am    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
I tried to get some from deere last week for a 720 gas RC and they could not get them. The had them in their system but when I ordered them they said they were obsolete. Same price as you were quoted.
Eugene Alt
PostPosted: Mon Nov 26, 2012 10:54 am    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
Had one done last year. Cut off outside of where they were clamped and on welded new tubing on.
thurlow
PostPosted: Mon Nov 26, 2012 1:32 pm    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
Ain't never had one-a-them, but I've added additional remotes on early model 4020s and have used hydraulic hose; works fine. Whoever makes up your lines can add the correct ends; just carry the old ones with you............
bigboreG
PostPosted: Tue Nov 27, 2012 4:43 am    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
I should try talking him into going with tubing. Hopefully i can find someone who can make the bends. Thanks for your input guys!!
bulldog42
PostPosted: Thu Nov 29, 2012 5:27 am    Post subject: Re: 630 hyd lines Reply to specific post Reply with quote
Replaced good used ones on my 620. got them from mcgrews I thing 90 dollars apiece but where good and they guarteened them.
