| Author |
Message |
dinosaur New User
Posted: Mon Nov 26, 2012 8:55 am Post subject: Wisconsin TRA10D |
I have a TRA10D motor that I"ve been using on my generator, that now after a few hours of running, won"t start.
While it was running, the condensor wire pulled out, so I replaced it with another condensor that I had, started back up and ran for another hour until I shut it down.
I"ve had the carb redone, and I"m getting spark. It does seem like it wants to start but doesn"t. Using the starter it will "pop" once in awhile and I can feel the head getting warm like it"s firing but not stong enough to do it under its own power.
Would the "wrong" condensor cause this and if so, what is the correct one to use? Any other thoughts? Thanks |
| Back to top |
joe csuti Long Time User
Posted: Mon Nov 26, 2012 1:19 pm Post subject: Re: Wisconsin TRA10D |
The correct pn for condenser is yd-315,as far as hard starting,1st thing check that points not burned/pitted due to useing wrong value condenser,also try cleaning point contacts,my have oil/dirt on same due to oil leaking past push pin.If points burned/pitted & need replacement,a kit is avail with points,condenser,condenser clip,& terminal pn yq-12,points alone are pn yd-314.
If points prove not to be problem,try shooting a shot of gas,carb cleaner or starting fluid into carb & see if eng fires/runs,if it does problem with carb or fuel supply to same,possible causes,dirt in carb,float stuck,hi-speed needle set too lean,carb loose & sucking air at mounting gasket,plugged/restricted gas filter or weak/bad fuel pump(if eng has)bad/plugged fuel lines.
If eng fails to start when priming carb or eng only runs till prime burns off look for blown/leaking head gasket,carbon lodged between valve seat/valve not allowing valve to close,carbon buildup on valve(s) stem causeing valve(s) to stick or valve clearance may need an adj as same may be adjustable,I don't know about this as I've never worked on this mod eng,maybe one of the other guys can add some input on this.
If eng has magneto ign check that flywheel key not bent/sheared changeing ign timing,online parts list shows eng came with magneto or 12v ign. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
