| Author |
Message |
Michael Johns New User
Posted: Mon Nov 26, 2012 12:08 pm Post subject: 706d hydralic hook up to 3pt hitch back hoe |
having problems connecting back hoe to 706D Farmall, have to constantly change aux. lever position for pressure, what am I doing wrong?
all advise appreciated, using the couplings on the left front of steering. |
| Back to top |
mkirsch Tractor Guru
Posted: Mon Nov 26, 2012 12:21 pm Post subject: Re: 706d hydralic hook up to 3pt hitch back hoe |
Can you please be more specific about what happens? What do you do, then what does the tractor do?
Does the lever pop back to neutral on its own? That is normal. You need to tie the lever back with a bungee cord or baler twine.
Are the couplers good? Bad couplers, or poorly seated couplers, can seal up and not let fluid flow. |
| Back to top |
Posted: Mon Nov 26, 2012 12:25 pm Post subject: Re: 706d hydralic hook up to 3pt hitch back hoe |
I forgot, been so long since I used it, should I tie it down in the forward position or up to the rear position? |
| Back to top |
Posted: Mon Nov 26, 2012 12:43 pm Post subject: Re: 706d hydralic hook up to 3pt hitch back hoe |
It's much easier to tie it up in the rear position, because down and forward you have to deal with the float position.
If you're tying it down and forward, odds are good the lever keeps slipping into float on you.
Switch the hoses around on the couplers if the backhoe runs backwards on you with the lever tied back. |
| Back to top |
Farmboy856 Regular
Posted: Mon Nov 26, 2012 1:47 pm Post subject: Re: 706d hydralic hook up to 3pt hitch back hoe |
I agree with MKirsh---I think it is probably dropping into the float position--- but then again, there is more easily accessible things to tie it off to in the down position. I remember when using the Shaver fencepost driver years ago on a 706 in a one-man set-up, I cut a small block of wood that wedged between the lever and the platform and held the lever in the up position. |
| Back to top |
mazemeister Regular
Posted: Mon Nov 26, 2012 2:33 pm Post subject: Re: 706d hydralic hook up to 3pt hitch back hoe |
there is a special float lockout bolt down by the pivot for the levers. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
