Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
no oil pressure
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Josh Cartey
PostPosted: Mon Nov 26, 2012 2:12 pm    Post subject: no oil pressure Reply to specific post Reply with quote
This message is a reply to an archived post by Josh Cartey on July 05, 2012 at 14:42:05.
The original subject was "no oil pressure".
I have now drained the oil and changed it. There was a lot of sludge in the bottom of the crankcase. I cleaned it all out and refilled with new oil. Started the tractor up for a min and it started to knock. Shut it down immediately. So now it"s getting no oil. Any ideas?
F-I-T
PostPosted: Mon Nov 26, 2012 2:25 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Year, make, model of tractor?
rickdeere
PostPosted: Mon Nov 26, 2012 2:35 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
if its a johndeere the oil coupler might have broken,you can take the rod cover off and look down in the to see if oil pump shaft is turning.
Josh Cartey
PostPosted: Mon Nov 26, 2012 2:47 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
1949 John deere A.
J. Everett
PostPosted: Mon Nov 26, 2012 2:52 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
I can only "hope" that you changed the oil filter as well. It will also be covered and plugged by the same sludge...thus no oil pressure. Best of luck .
rickdeere
PostPosted: Mon Nov 26, 2012 3:56 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Just changing oil doesnt stop oil pressure. What all did you do????
wijim
PostPosted: Mon Nov 26, 2012 5:16 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Oil pump drive coupler broke I bet.
elkcagg
PostPosted: Tue Nov 27, 2012 12:53 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Did you clean the screen around the pump inside the crankcase? Did you have pressure before changing oil? If you did, you may have overtightened the oil filter nut and collapsed the canister.
F-I-T
PostPosted: Tue Nov 27, 2012 2:37 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Josh cartey wrote:
(quoted from post at 15:12:44 11/26/12) This message is a reply to an archived post by Josh Cartey on July 05, 2012 at 14:42:05.
I went back and read your original post from July, and you were not getting any pressure then. Did you do anything to determine why it is not pumping? Or did you just change the oi, and hope that the tractor elves would stop by and fix it? Sorry to be cute, but what have you done since July to solve the oiling problem? Running, even for a minute, with no pressure, which you know you don't currently and did not have back in July, is just making a parts tractor for some one else.
It's time to take these many good suggestions, and rule out problems systematically. First, DON'T RUN THE ENGINE UNTIL YOU GET IT TO OIL! Next, remove the cover over the crankshaft so that you can see that the oil pump drive coupler is intact and that the oil pump shaft turns when you rotate the engine. Next, verify with air pressure or some other engine, that the gauge you have does indicate correctly. Turn off the gas, ground the plug wires so you don't start a fire, and remove the plugs so you can spin it over pretty fast. If it the pump drive is turning, if it is filled with oil, if the filter canister is not cracked so as to allow oil to vent out of the top of the canister without getting to the lines, if the screen is not clogged beyond imagination, oil should pump even when turning over by hand/starter.
Now...did you have the pressure adjusting spring/reed apart? Make sure is it intact and correctly assembled, but don't run it anymore until you get it to oil. That's one of the simplest little regulated pump systems you can find. It can only go wrong in a few places.
Josh Cartey
PostPosted: Tue Nov 27, 2012 7:56 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Ok here is the full story. I have had the tractor for eight years. I
have ran it those eight years many of times at parades and
tractor shows. It had an old oil pressure gauge on it that didn't
work. I assume it was getting oil and had oil pressure those
eight years because its never had any problems. I bought new
gauges for it back in July. When I got those installed I noticed
the oil pressure gauge said nothing. I quit working on it till now.
Yesterday I decided to change the oil and filter cause it had
never been done. It had lots of sludge in the bottom of
crankcase. I cleaned it out and refilled with oil and new filter. I
started it up and after running for a minute it started knocking.
Shut it down immediately. I know that changing the oil and
filter should not make it stop getting oil but it must of been
getting oil previously since in never knocked before. That's
where I'm at now.
F-I-T
PostPosted: Tue Nov 27, 2012 10:34 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Josh cartey wrote:
(quoted from post at 08:56:56 11/27/12) Ok here is the full story. I have had the tractor for eight years. I
where I'm at now.
Ok then. Here's where you start, from above post:
Fredsjdb
PostPosted: Tue Nov 27, 2012 3:58 pm    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Josh, when I bought my 50 A it had no oil pressure. I checked the coupler and it was still intact. I found someone overtightened the oil filter cover nut breaking the oil pressure regulator housing that is located on top of the filter canister. If this is your problem it can be fixed without tearing to much of the tractor up. It's not a fun job. You"ll have to locate a replacement oil pressure regulator and probably a new stud. Check to see if you can remove the filter cover, if it just spins that"s a good indication the oil pressure regulator has been broken. Good luck. Fred
rickdeere
PostPosted: Wed Nov 28, 2012 7:40 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
Now how did you get sludge out????? And did you use john deere oil filter?????now if you didnt use john deerer oil filter get one, and take oil line off turn engine by hand until oil comes out line.something is just not adding up, also you should never run a tractor without oil gauge, aftermarket oil gauges never read correctly either always way lower than the real ones.
rickdeere
PostPosted: Wed Nov 28, 2012 7:46 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
When I replace canister top on my b I had to pull the entire block so I could have room to work, A,s are some bigger.
Josh Cartey
PostPosted: Wed Nov 28, 2012 11:21 am    Post subject: Re: no oil pressure Reply to specific post Reply with quote
I have looked at it and it appears to be a broken coupler.
Looks to be cracked looking through the crankcase cover.
Bout to tear it apart to fix. Thanks for the help everyone! It's
been quite a few years since I worked on one. Just needed a
little refreshing.
Goto page 1, 2  Next
Page 1 of 2
