| Author |
Message |
Brad Buchanan Long Time User
Posted: Mon Nov 26, 2012 7:29 pm Post subject: Might give the Machinists a chuckle (pics) |
Hey everybody.
I set up a pump to fuel some small heaters and due to poor planning on my part the nozzle didn't fit the hole in the tanks!
It was the holiday weekend and I didn't have any luck finding an adapter to do the job.
Finally I got disgusted and pulled out some 35mm hex aluminum bar that I had and went to work.
A carbide blade on the table saw sliced off a 1 1/4" section and I set up the drill press with a 13/16" hole saw.
I removed the 'plug' and drilled and filed 'till I had the hole to 7/16".
I welded the plug into the end of the nozzle and after some filing and shaping it actually works!
I will never be mistaken for a real machinist I fear.
Brad
| Back to top |
Ted in NE-OH Guest
Posted: Mon Nov 26, 2012 7:39 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
Wouldn't a funnel work? |
| Back to top |
Justin SE IOWA Long Time User
Joined: 21 Sep 2010 Posts: 574 Location: Oskaloosa Iowa
Posted: Mon Nov 26, 2012 7:54 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
Thats awesome! Nothing like thinking outside the box! |
| Back to top |
BOB HAWBECKER Regular
Posted: Mon Nov 26, 2012 8:33 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
he just wanted to play with his toys
ya did good!
oh the saw thing we used to turn saw blade around and cut alum. siding in the younger days. |
| Back to top |
casenut1 Tractor Expert
Posted: Mon Nov 26, 2012 9:37 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
that's to simple. |
| Back to top |
JMOR Tractor Guru
Posted: Mon Nov 26, 2012 10:26 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
| casenut1 wrote: | | (quoted from post at 01:37:26 11/27/12) that's to simple. | Bad part is that back when unleaded gas first came around, all the auto supply stores sold a stepped plastic sleeve that slipped over a big leaded nozzle so that it would fit into the small filler hole on unleaded-only cars. Probably costs less than 50 cents. Can't find my old one & never see them in stores anymore. Probably against some law now. |
| Back to top |
Dave Sherburne NY Tractor Expert
Posted: Tue Nov 27, 2012 6:42 am Post subject: Re: Might give the Machinists a chuckle (pics) |
Anybody can do it the easy way. |
| Back to top |
Steve in VA Regular
Posted: Tue Nov 27, 2012 7:47 am Post subject: Re: Might give the Machinists a chuckle (pics) |
"If we don't have the part, we'll make the part.
If we don't have the tools to make the part, we'll make the tools to make the part." |
| Back to top |
JRSutton Tractor Expert
Posted: Tue Nov 27, 2012 11:20 am Post subject: Re: Might give the Machinists a chuckle (pics) |
You know, there IS a much easier way.
You could have used a chain saw to cut off a spare chunk of steel from your wife's car, melted it down and just cast that little sleeve. |
| Back to top |
danofarming Regular
Posted: Tue Nov 27, 2012 6:50 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
I remember a joke about the US making the worlds smallest drill bit. sent it to the russians, they drilled a hole in it and sent it back! |
| Back to top |
scotc Tractor Expert
Posted: Tue Nov 27, 2012 9:32 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
We just stuck an old milker inflation on the end of the gas nozzle. |
| Back to top |
671DKS Regular
Joined: 02 Dec 2009 Posts: 40 Location: Wichita, Kansas. NW of Benton
Posted: Wed Nov 28, 2012 8:47 pm Post subject: Re: Might give the Machinists a chuckle (pics) |
I'm sitting here trying to figure out what to use the leftover hex piece for now... |
| Back to top |
