jd 730 LP converter kit
steeda50ho
PostPosted: Mon Nov 26, 2012 9:44 pm    Post subject: jd 730 LP converter kit Reply to specific post Reply with quote
hi anyone know where i can buy a rebuild kit for a century M4 LP gas converter for a 730 deere
thanks
David from Kansas
PostPosted: Tue Nov 27, 2012 10:38 am    Post subject: Re: jd 730 LP converter kit Reply to specific post Reply with quote
You might try Nick Barbieri in NY at 516 221-4116. He has an ad in Green Magazine quite often.
CLW
PostPosted: Tue Nov 27, 2012 11:08 am    Post subject: Re: jd 730 LP converter kit Reply to specific post Reply with quote
David is correct. Nick would be your best bet for LP parts.
Hugh McKinney
PostPosted: Tue Nov 27, 2012 12:13 pm    Post subject: Re: jd 730 LP converter kit Reply to specific post Reply with quote
I found a place in Minnesota called Carb and Turbo Systems, very nice folks, who also provided generous tech support. One thing you might find with your M4, sometimes the end (the aluminum casting which holds the M4 to the bracket on your 730) warps, just a tiny bit. Be prepared to machine it perfectly flat, since, at 200 PSI, the neoprene gasket will not always hold otherwise. Just sayin'. Good luck.
