Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Electrolysis Tank Evaporation
Post new topic    Yesterday's Tractors Forum Index -> John Deere
woodvue
PostPosted: Tue Nov 27, 2012 6:26 am    Post subject: Electrolysis Tank Evaporation Reply to specific post Reply with quote
I haven't used my electrolysis tank is quite a while and noticed that the level in the tank has been lowered by evaporation. Lowered by about 6". My question is when I top it up with water will I have to add new lye? BTW its an old plastic water trough. Thanks
Neven
PostPosted: Tue Nov 27, 2012 6:39 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
I think that's common. I usually top it off.
F-I-T
PostPosted: Tue Nov 27, 2012 7:01 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
woodvue wrote:
(quoted from post at 07:26:33 11/27/12) I haven't used my electrolysis tank is quite a while and noticed that the level in the tank has been lowered by evaporation. Lowered by about 6". My question is when I top it up with water will I have to add new lye? BTW its an old plastic water trough. Thanks
Nope, you just dehydrated the lye and such back into crystalline form, so it's anhydrous. Mine is a large Rubbermaid stock tank and it is dry as well. I'm going to fill it soon, and it will all come back just like table salt in water.
woodvue
PostPosted: Tue Nov 27, 2012 8:43 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
F-I-T wrote:
(quoted from post at 16:01:17 11/27/12)
That's what I thought but it's been a long time since chemistry class. Thanks guys.
lockrotor
PostPosted: Wed Nov 28, 2012 6:28 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
F-I-T could you send me a link to understand how this works
better and any type of photos about the tank and other items
that are used to make it work.
F-I-T
PostPosted: Wed Nov 28, 2012 6:38 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
lockrotor wrote:
(quoted from post at 07:28:06 11/28/12) F-I-T could you send me a link to understand how this works
Here's a link to a pdf I wrote, and some photos of my newest M.O.A.T...."Mother of all tanks". I use a 5 volt/200 amp computer TTL rack supply and can clean about half an "H" rear wheel at a time, but I seldom run over 20 amps. At a low voltage like this, you can put your hands in the water and not get a tingle because 5 volts is too low to pass through your galvanic skin resistance. 12 volts work, too, but you'll get a tingle if you don't shut it off first.
http://www.fboerger.com/Articles/Electrolysis.pdf
lockrotor
PostPosted: Wed Nov 28, 2012 10:51 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
Thanks F-I-T I might try this some day.
F-I-T
PostPosted: Wed Nov 28, 2012 10:54 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
lockrotor wrote:
(quoted from post at 11:51:17 11/28/12) Thanks F-I-T I might try this some day.
I predict that when you do, you will be amazed.
CaseRider
PostPosted: Thu Nov 29, 2012 8:57 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
Electrolysis works great on lots of stuff...including rusty 100+ years old horseshoes fresh from the pasture! But on some things, it just doesn't work so well. You have to try it and see for yourself.
Also, I don't think just any battery charger will work. I tried it with different kinds of chargers, but only got it to work with ones that did not have the automatic shut-off capability.
Anyway, here's another link with someone else's electrolysis strategy:
http://www.fordgarage.com/pages/electrolyticderusting.htm
F-I-T
PostPosted: Thu Nov 29, 2012 8:43 pm    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
CaseRider wrote:
(quoted from post at 09:57:09 11/29/12)
The problem with using a carbon rod for an anode is that there just isn't sufficient surface area to pass enough electrons to do much work. If you can find carbon sheet, you might have a chance. But with a 1/2" rod, only about 1/3 of it "sees" the part, so you have a very skinny surface. Now they do work great to use for inserting down into a part to clean a bore, such as a carburetor, but I still shield them with loose plastic mesh.
CaseRider
PostPosted: Tue Dec 04, 2012 11:40 am    Post subject: Re: Electrolysis Tank Evaporation Reply to specific post Reply with quote
F-I-T wrote:
(quoted from post at 21:43:31 11/29/12)
Yeah, maximizing the anode surface area is one key to the succes of this technique. A setup like your tank is ideal.
The plastic mesh is an interesting idea...I'll have to give it a try next time.
For a while I was trying to use electrolysis to de-rust some headlight buckets from a 1929 Ford truck...with very limited success. Electrolysis at the inside surface of the headlight bucket was especially poor. I thought that suspending an electrode in the headlight bucket would help, but it wasn't an overwhelming success either. Maybe part of the problem is that most of the headlamp bucket was originally copper plated. I suppose there could a preferred path for the electrical current that would inhibit electrolysis of the iron oxide.
